Question about Poulan Garden
How do I install the kill switch spring and wire on a Poulan P3416 chainsaw?
2 Suggested Answers
  • 2210 Answers
SOURCE: How do I install a Poulan P3416 ignition switch (kill switch) spring and wire? The old one was so rusted it was in pieces, so I have no clue how to insert the new spring or the wire. Thanks for your h
Pop into your local garden machinery shop if its too old to find a handbook for. You might find someone who knows when he see's it.
Posted on Mar 30, 2015
I just bought a new Poulan Model P3416 chaisaw (34cc) and I have followed the starting instructions and have not been able to start the saw. I have even varied the instructions but no luck. Any thoughts...
see if your switch is in run position and then pull your spark plug out see if it is wet, then see if it is sparking when you ground it and pull cord to roll over, if all is good hold throttle wide open and crank over without choke on, probably flooded, good luck
Aug 19, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Poulan chainsaw / model p3416 16" manual What brand of motor oil is required for this saw?
There is no actual brand required, you need two stroke oil designed for use in a chainsaw to mix with the fuel at 25-1, try to get oil manufactured by a chainsaw company, and you need non fling chain oil for the oil tank at the front of the saw to lubricate the chain.
Jul 24, 2011 | Poulan Garden
Do you have the email address for Poulan to contact direct ?
I went to www.poulan.com and found a few phone numbers and here they are;
wheeled
1-800-849-1297
handheld
1-800-554-6723
all McCulloch
1-800-521-8559
Hope this helps and please rate my solution!!
Nov 22, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
The screws do not have a flat head? How do I adjust the carb?
if you have plastic caps on the screws you have to pop them off to turn the screws. some screws have a slot and some don't.
for the one's that don't use a pair of needlenose plyers to turn them.
Jun 23, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Replace starter rope spring part no 545008013 on the poulan p3416 chain saw. How to get the spring coil seated in the housing, and then get the starter rope part on top of it.
Hook the spring at the inner mount, then wind the spring CCW until the spool assembly can be attached to the outer spring, then continue to wind the spool until the spring is about half-tight or so. It must be able to wind about three or four turns more without becoming 'bound' which would lock the spool and not permit return of the cord. When the spring is wound, wedge it so that the cord can be attached, the work the cord around the spool so that the outer end will only project beyond the cord port a little way. Pull the cord out to make sure that the spring doesn't bind at full extension, the apply locking pliers to the cord to be able to attach the handle. Melt the cord ends to prevent the knots from pulling out. Hope this helps!
Jun 15, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Poulan p3416 .3 1/2 years old . gas cap has become really tight,from the first turn
Poulan.com
http://www.ordertree.com/modelinfo/PWE/P3416-Gas-Saw-Type-2/75.P3416-Gas-Saw-Type-2.1.59.1.html
Handle, Chassis, & Bar Assembly
Item 15, $3.09
Maybe a little cross threaded or swolen from contact with fuel.
Please verify this is your fuel cap. HTH
Lou
Oct 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Starter Pulley Jammed
A new spring can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool when inserted. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and wind the withdrawn cord onto the spool. GL
Lou
May 28, 2009 | Poulan Garden
Poulan Pro 42 chainsaw will not start
I had the same problem on a P3416 saw. I had a new Champion plug and coil installed. I tested the plug by removing it and plugging it in the coil wire and ground the end of the plug on the engine block. It did not spark so I bought another plug. This one fired but it was real weak so I loosen the coil and slipped a piece of light folder paper between the coil and magnets and tighten the bolts. Got a better spark and got it to run.
Mar 04, 2009 | Garden
Garden Logo
66 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
