Question about Yamaha Rx-v565 Receiver
How to fix this...I have RX V565 RECEIVER, when I press the setup on the remote control it wont work. What should I do?
Is there any key on the unit to go to setup menu other than using a remote control? Thank you
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
SOURCE: Problem is starting Auto Setup on my Yamaha rx-v463 receiver
You need to press the AMP button before you press the ENTER button. Always press AMP first when selecting menu, enter, any surround mode, or one of the amp functions in ORANGE above the green numeric buttons.
Got this from Yamaha.
BG
Posted on Feb 13, 2009
CAYPIANAN
  • 227 Answers
SOURCE: The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
Posted on May 22, 2009
smarthome2
  • 1114 Answers
SOURCE: My Yamaha receiver model rx-v565 audio is putting
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: Yamaha RX-V630 Is not responding to the remote control unit
Replace the remote control with a universal remote (e.g. Logitech). It is more advanced and very user friendly with a help function if anything doesn't work.
Just follow the instructions in the unit's manual.
If you drop it; be sure to replace the batteries correctly.
Keep good batteries in it and enjoy the convenience of only one remote.
If still in trouble; just visit your local Yamaha dealer for help.
Posted on Dec 26, 2009
Yamaha rx-v565 wont turn on. Not "Click Sound" when Press On Button
It sounds like the output ic and or transistors have blown and need replacing. Did you short the speakers or cables?
Dec 01, 2016 | Yamaha Rx-v565 Receiver
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Mar 30, 2015 | Yamaha Rx-v565 Receiver
Yamaha RX-V359 the remote sensor in in the unit is not working. I have tried the remote control on another machine and that works
If the remote is working, but not with your receiver, there is maybe ID mismatch. Both the remote and receiver can be set to either ID1 or ID2 - this is used when you have 2 receivers nearby, so that both of them don't react on commands from both remotes.
See the "Advanced setup" of your manual. On receiver you can check/change the ID code by powering the receiver on (press STANDBY/ON) while holding down the STRAIGHT button on front panel. Display will show "Advanced setup". Use "program < >" keys to navigate the menu until you got to "REMOTE ID-XYZ". Then press STRAIGHT to select ID1 or ID2. Now press STANDBY/ON to turn the receiver off. After turning it on again, it will use the new settings.
You can also try to reset the remote control codes to factory defaults. On remote, press CODE SET with a tip of a pen or pencil. TRANSMIT light on remote will blink twice. Now press SETUP on the remote and then "9981". TRANSMIT should now blink twice and remote control is set to factory default codes.
Oct 12, 2014 | Yamaha Audio Players & Recorders
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
My yamaha rx-v565 wont turn my sub woofer on.It detects that it is there during setup but doesnt turn it on during music or movies.
make sure the switch on your sub is on, and also if there are no "sub signals" then it wont kick on tru listening/watching somthing with alot more bass to see if it kicks on
Dec 17, 2009 | Yamaha Rx-v565 Receiver
Trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Sep 05, 2009 | Sherwood RX-4109
    Zone 2 volume control
    Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
    How do I setup Zone 2 on the RX-V661 Using the internal power amp.
    Setting the RX-V661 remote control to operate Zone 2
    1. Using a ballpoint pen or similar object and press the Code set
    button. The Transmit indicator on the remote should flash twice.
    2. Using the numerical key pad on the remote and key in 9992, the
    Transmit indicator should flash.
    You will now need to assign the receivers internal amp for Zone 2.
    1. Set the remote control selector to AMP. Selector is on side of remote.
    2. Press the Set Menu Button.
    3. Arrow down to Manual Setup.
    4. Press the Enter button.
    5. Arrow to the Sound Menu option and press Enter.
    6. In the Sound Menu arrow to Speaker Set and press Enter.
    7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
    8. Press the Return button to exit out and return to the Manual
    Setup.
    Apr 05, 2009 | Yamaha RX-V661 Receiver
    Sherwood rd7103 rec.
    no listing for Sherwood receiver. must do the remote "search" function. here is how:
    1. Turn on your TV.
    2. On the remote control, press TV once.
    3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
    4. Using the number pad, enter 9-9-1. The TV key will blink twice.
    5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
    6. Press the SETUP key once to lock in the code. The TV key will blink twice.
    Hope that helps!
    Feb 28, 2009 | Sherwood RX-4103 Receiver
    Comcast remote
    The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
    1. Press and release AUX
    2. Press and hold SETUP until the remote blinks twice
    3. Type 993
    4. Press and release VOL-
    The remote should blink four times to confirm unlock.
    Jul 05, 2008 | Yamaha RX-V1400 Receiver
    Yamaha Rx-v565 Receiver Logo
    53 people viewed this question
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
