Initialising and finalising dvd -rw disc
Cannot initialise or finalise disc
    Sergeant:
  • 283 Answers
Hi John, several reasons it could be, first off the DVD and Disk has to be compatible and finalise will only work if it was initialize on this DVD recorder. Cheers Greg.
Posted on Mar 30, 2015
I had a bunch of pictures on a DVD-RW that I transferred to a more permanent media. I then reformatted the DVD-RW disk. Now when I go to properties it says: Used space: 3.49 GB Free space: 906 MB How do I...
Rewritable DVD discs allow you to record and erase lots of times (up to 1000). Similar to DVD-R disc and DVD+R disc, DVD-RW is approved by DVD Forum, while DVD+RW not
did you finalise the disk after you finished the burn? depending on which burning software you are using some ask if you want to finalise the disk after a burn others just finalise or you might need to select multisession before the burn starts
hope this helps
Sep 08, 2011 | HP Computers & Internet
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
My camcorder will not give me an option in disc operations to finalise a disc which I recorded on (which I did initialise before starting- I have also tried it on another disc, initialise, record etc) I...
Are you using the AC adapter when trying to finalize? You cannot finalize using battery power only.
Link to your manual:
Canon DC210 Manual
(What format discs are you using?)
Instructions for finalizing begin on page 61.
Hope this helps.
Thanks for using Fixya.
Mar 11, 2011 | Canon DC210 DVD Camcorder
Finalising discs with canon camcorder
I do know that to finalize discs, you need to have your camera plugged in to a wall outlet, according to the owner's manual.
Jun 07, 2009 | Canon DC210 DVD Camcorder
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
Editing a DVD-R
I guess you read this on page 5 of the user manual.
DVDs initialised in VIDEO mode cannot be edited on the camcorder . However, they can be played on most DVD players and can be edited on a PC, but they must be finalised on the camcorder first.
Once finalised, there is no problem in downloading to a computer, but as the Canon DC210 does not have a USB connection the 'download' consists of taking the finalised DVD from the camcorder to the PC and working with it on the PC.
To finalise make sure you have the camcorder connected to the mains through the power adapter and the mains switched on before you start. Then switch on the camcorder and follow the instructions on page 61 of the user manual.
There is no need to transfer the DVD to a DVD-RW format to edit it.
Take your finalised DVD and place it in your PC DVD drive - you can use the operating system functions to transfer the DVD contents to a folder on the PC.
You'll need some commercially available software to edit the files you've transferred - a couple of suggestions are Magix, Adobe - there are many programs available.
Don't forget to rate this solution once you've tried it !
And good luck with the school project.
May 28, 2008 | Canon DC210 DVD Camcorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
May 11, 2008 | Canon DC210 DVD Camcorder
Canon DC210 Camera
The error message is because, either
1. the disc was initialised on another camcorder, or maybe a PC, or
2. The disc has a recording on it in a different TV system (PAL v SECAM).
From the above, it may be you're using the same disc in two camcorders. To be sure of seeing what's on your disc you need to keep it with the same camcorder from 'initialise' to 'finalise' .
To be able to see the disc on a PC you need to finalise it on the camcorder. There's no other way to get to see your work on a PC.
Unfortunately I think you've lost your recordings this time.
Feb 08, 2008 | Canon DC210 DVD Camcorder
How to view DVD rewritables
Petra
Had the same problem, You have to press the mode button down which changes it to play and brings up the frames in the viewer. Then select Func, it will then give you a menu screen that shows finalise. What the manual does not say is press down the mode button to get the camera in play mode, when you do the gree light for play comes on.
Hope this helps
Feb 04, 2008 | Canon DC220 DVD Camcorder
Mini dvd playback
Two problems here.
To JOA629 - You may possibly have initialised the disc in VR mode by mistake. VR mode discs will not play on a PC. Are you re-initialising the disc between when it works and when it doesn't ? If you're using VIDEO mode, are you finalising the disc on the camcorder before using it on the PC ?
To dewynn729 - you have intialised the disc in VR mode, which is a newer format than VIDEO mode. VR mode discs will produce .VRO file extension. Record your video on a disc initialised in VIDEO mode, finalise the disc on the camcorder (don't forget to plug the camcorder into the power adapter, and switch both on), then read the disc on a PC.
Dec 28, 2007 | Canon DC210 DVD Camcorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
