Question about OKI MICROLINE 3320 Matrix Printer
Can we print Courier New font with print quality UTL: Utility in OKI3320 printer
The printer manuals says Courier can be printer but doesn't give information on the specific fonts
    Top Expert:
  • OKI Master
  • 44,352 Answers
The printer normally prints the font set in the computer as it replicates the document
Posted on Mar 30, 2015
Hi - I can direct print to my Oki320T and it prints clearly using the resident font. When I print the same label from a pdf file (Using Courier or Courier Bold) it does not print clearly. - Do you know of...
I do not believe any font declaration in the pdf file is interpreted by the printer. PDF files are really nothing more than graphic files and are therefore printed in graphics mode not character mode.
Jul 18, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Print quality - what is hsd, nlq, utl, ssd mean on the printer
Hi Teresa,
These are just print quality settings
Super Speed Draft (SSD) - 435 cps. High Speed Draft (HSD) - 390 cps. Utility ( UTL) - 300 cps. Near Letter Quality (NLQ) - 75 cps
Hope this helps!
Please don't forget to rate
Jan 21, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
HOW TO SET FONT SIZE TO LQ COURIER AT 12 CPI AS DEFAULT
right click on the printer icon and go to printing preferences.. Under the print font, you may choose the available defaults.
Otherwise , as an alternative solution, each time you print a document, you will have to set the font to the desired type.
Sep 07, 2010 | OKI MICROLINE® ML390 Matrix Printer
Can not find a way to print in draft mode so toner
Laser printer can sometimes be set via the front panel on the printer for draft mode. Also, you might be able to set Draft Mode from the printer properties menu in the print driver.
The actual easiest way is change your font to something like Courier, 10P, which is a fixed spaced font.
When the document is finished, then you can do a "Ctrl A" and change the font to a more fancy font.
Don
Feb 18, 2010 | HP LaserJet 3600n Printer
How to set it 20 characters per inch
Where do you want to set the font?
Do you want the font as the default font on the printer or do you want the application to call the font?
Application wise, to get a 20 cpi character font, you need to place the font change into the document.
Remember, even if you set the default font as a 20 cpi, if the application calls for a 10 cpi font like Courier, the printer will change the default font to the 10 cpi font for the life of the current print job unless there are additional font calls within the print job.
The software (Application always overcomes default settings)
Don
Feb 15, 2010 | Panasonic KX-P3626 Matrix Printer
Does the Epson Stylus Photo R340 Printer print non photo documents in plain text?
yep, these photo printers print text aswell, just designed to give a better quality photo print
Dec 03, 2009 | Epson Stylus Photo R340 InkJet Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
POOR RINT QUALITY ON 4 PART INVOICE/DELIVERY PAPER
SRibbon wont effect multi part forms, well it will only effect the top one. Most dot matrix printers also have a impression adjustment, sounds like you need to increase yours.. it brings the print head closer to the platen.
It could also be the paper, not having much carbon to print the next part.
I've also notice you ask a lot and suggest you may need more than simple one line free answers.
Font problem will be program or print driver or even possible printer default settings (read printers user manual) .ie.font used by software is probally not supported on 2nd line so a default font is used
Once you have read manula you will find and know how to change print quality ie draft or LQ.
After reading manual you should also discover you can do print quality adjustments via the oprint driver.
Jan 26, 2009 | Epson LX-300 Matrix Printer
OKI MICROLINE 3320 Matrix Printer Logo
93 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
