Question about Garmin 010-00658-10 Forerunner 405 Gps Receiver With AntSportTM Wireless Technology Black
My forerunner 10 is not charging and no power
Have tried holding down the buttons nothing working
My Garmin 101 won't turn on, even with new batteries. Any ideas?
You said your watch was a "101", I assume that is a Forerunner 101.
The instruction say "press and hold the power button until the welcome page is displayed".
Perhaps you are not holding on to the power button for long enough?
Incidentally, if you do not have a copy of the instruction manual, you can obtain a copy from their web site "garmin.com". "Select support" and "manuals", fill in all three boxes and select your manual from the list given.
Jan 26, 2010 | Garmin Forerunner 101 Gps Training Watch -...
The power wont turn on
The instructions say that you should "press and hold the ON" button (top left).
Perhaps you are not holding it on long enough (I think that a delay is built into the buttons to prevent accidental operation due to catching it on something).
Jan 17, 2010 | Garmin Forerunner 205 Gps Training Watch
Garmin watch
If you haven't already done so, try replacing the battery.
You can remove the battery cover with a small coin, check the type (all batteries are marked) and buy a replacement.
Jan 16, 2010 | Watches
I've charged up my Garmin forerunner 405 for the first time and it's stuck on the language setting page. I can scroll through the languages, but can't press enter to select the Language ("English")??...
It looks like you have so called cold push button. In fact there is nothing to do with push button as the fault is in contact or in microchip, but that's a long story to explain. You probably would be able to fix it with my help, but as I understand, your Garmin is brand new and still under the warranty, so, there is no reason to open it yourself and loose the warranty. My advise is to go back to the retailer who sold it and ask to change it for the new one.
Rate me, please.
Jan 08, 2010 | Garmin Forerunner 405 Sports Watch/ HRM
Can i set the f50 to beep after each mile i run?
Yes. When in Train mode, press and hold start/stop to enter the settings mode and press the View button until "Auto" appears to turn on AutoLap, then set the distance to 1.00. your watch will beep at every mile and automatically record each mile split for you. ... its one of my favorite features!
Sep 30, 2009 | Garmin Forerunner 50
The unit does not switch on nor does it show battery charging in progress when attatched to the charger unit
The device may just be locked up and needs to be reset so that it can start up normally. To do a reset on the device, make sure the unit is plugged in to the charging cable/cradle and connected to power. Next press and hold the Mode + Reset buttons at the same time for approximately 10 seconds. After releasing the Mode + Reset buttons, attempt to power the device on normally.
Jun 11, 2009 | Garmin Forerunner 205 Gps Training Watch
CANNOT PAIR FORERUNNER 50 WITH HRM, FOOT PAD OR PC
maybe you can find something helpfull here:
http://www8.garmin.com/support/userManual.jsp?market=67&subcategory=68&product=010-00679-05
Good luck.
Feb 26, 2009 | Garmin Forerunner 50
Garmin 010-00658-10 Forerunner 405 Gps Receiver With AntSportTM Wireless Technology Black Logo
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
