I think I pressed a wrong button on my USB keyboard when I press the f button fb shows up or if I press the l button my settings screen comes up ..maybe hotkeys idk how to stop it from happening
  • 5,631 Answers
There is no wrong button. I really don't know what's the problem but a friend had a similar problem and he later told me it was the effecto of some malware.
So do a check with Free Malwarebyte's Antimalware
Download it and update it, than scan tour computer.
DETECTS REMOVES MALWARE FROM YOUR PC
you cand sign up for free version, nothing to pay no charges
Posted on May 12, 2015
5 Suggested Answers
SOURCE: Keyboard won't type
The problem ended up not being with the connect buttons. I am assuming after I changed the battery in the keyboard it deleted the encryption code. I did the Ctrl-Alt-F12, THEN, the "connect". Put in the encryption codes and Hallelujah, the keyboard is working again. Almost pitched the darn thing and purchased new. Hope this helps someone else.
Posted on Mar 04, 2009
SOURCE: External keyboard messing up Gateway settings
You have to unlock the FN key on your keyboard. It seems to be locked in place. I had the same problem and resolved it by looking for a "num lock" , "function lock" or actual blue image of a lock on the keys. Mine is located under the "Scroll" button. Press this along with the FN and your keyboard should go back to normal
Posted on May 02, 2009
  • 11800 Answers
SOURCE: hp 5189 keyboard connection problem
Dumb questions: have you put the batteries in the keyboard? Have you installed the drivers?
If yes on both then try moving the dongle  to a better position - an USB socket to the front of the case.
Posted on Sep 13, 2009
Testimonial: "The dongle is at the front of the pc, tried new batteries though.. Worked like a charm. Cheers for the help, silly of me really;)"
  • 4 Answers
SOURCE: How to control Asus A6R Fn keyboard? when I type
It looks as though you have Numbers Lock turned on. On my Asus x58C this is tuned on and off using the blue Fn and NumLk keys. When its turned on there is a padlock symbol located above the keyboard which is lit. If it is, then hold down Fn then press NumLk and it should turn off. Hope this helps you
Posted on Feb 14, 2010
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Boots to a blue screen but does not recognise the keyboard you have the option for esc f1 or f10 but unable to do anything since you can not use the keyboard. I have tried a usb and ps2 keyboards
As per your description, if I am not wrong, your bios screen comes ok but the blue screen comes when the actual Operating System loads.
This shouldn't happen with a PS2 (the green round pin - to be fitted in green socket only) keyboard. If it does, then you have problem with the motherboard.
But, if you have a USB keyboard, try putting the keyboard in bottom part of USB(Port 12 - as shown in the picture), next to VGA connector.
You may also need to enable USB Keyboard Support from the BIOS - which can be done by pressing "Del" key at the startup. - and save it by pressing F10 - and exiting BIOS.
Nov 13, 2010 | ASUS PTGD1-LA Motherboard
I think there is a part missing to this cordless keyboard . I am handicapped and just can't figure out. i bought 2nd hand
the keyboard should have,,
1.) the keyboard
2.) usb adapter
3.) driver cd
1.) insert the usb adapter to the computer
2.) install batteries on keyboard.
3.) INSERT DRIVER CD AND FOLLOW INSTRUCTIONS
4.) If noting pops up on installin the cd then skip step and continue
5.) button on keyboard press the connect button on the usb adapter.. (if there isnt one skip this step)
6.) when the driver installer comes up, click install drivers automatically
Thats it your done!!
6.) press connect
Mar 05, 2010 | Logitech Cordless Desktop Deluxe Optical...
The set is connected by USB to the laptop but I can't get it to work. Reset buttons, new batteries, checked usb plug, blown clean,nno dust, light on the receiver is on, lights flicker when the reset button...
it seems that there is connectivity problem.. as your sensor is not receiving signal from keyboard or mouse.....you have to make connectivity by pressing button on sensor then press button on keyboard....similarly press sensor button on sensor then press button on mouse.....try this and do reply me
Oct 03, 2009 | Logitech Cordless Desktop EX110
Have plugged a MS USB wireless keyboard and mouse into USB port on baby - to use big screen and keyboard. It works well, but when I unplug USB keyboard, the baby's own keyboard won't work properly ie when...
Hello, your numlock keys are ON, find your Num Lock button and press it off.
It can be a 2 button combination like FN(function button) + Num Lock button. Then it should work.
other way is to press numlock on your external keyboard and then disconnect the board. see if it works.
Jun 26, 2009 | Advent 4211c Notebook
Apr 15, 2009 | Gateway 2520915 Keyboard
Wireless belkin keyboard
Hi. I have just worked out how to solve this as I had a similar problem. When you change the batteries of a Belkin Wireless Keyboard model F8E332ukBNDL you need to reconnect the keyboard to the wireless receiver that plugs into the USB port. To do this you press the 'Connect' button on the receiver and also press the green LED connect light at the top right of the keyboard - the one that flashes each time you press a key. I'm not sure in what combination you press these but I pressed them both and it worked.
May 16, 2008 | Belkin (F8E832-BNDL) (DBF8E832BNDL)...
TOSHIBA Satellite L30-10X Keyboard Set-up
Its just the problem with your USB drivers. Just update your drivers. You'll be fine
Apr 26, 2017 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
