Question about Home
How do I remove water restrictor - Home
  • 3,382 Answers
You should not, but you can drill it out.
Posted on Apr 02, 2015
How do I get more water pressure from my american standard shower set
Hi Fran:
Most shower faucets now are equipped with flow restrictors. It is possible with some units to remove the flow restrictor plate from the shower nozzle. It has to be dis-assembled to do that.
Regarding the lack of hot water, that would usually be a different problem and will be related to the hot water source.
Hope this helps.
Dec 30, 2015 | American Standard Plumbing
I have bought several shower heads as the spray pressure is low but none have helped. The pressure is ok on low setting on half heat but too cold. On full heat its too hot on min setting. Help plz ?
The problem is that all shower heads sold now have to be low water volume. You can take the restrictor out and see if that helps. Look for a blue or white plug type insert in the fixture that has a slot on it. Pull it out and you should be good.
http://homeguides.sfgate.com/remove-water-restrictors-showerheads-27817.html
and http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html
Jun 22, 2015 | Home
Installed a new faucet and no water comes out
Since your question is so vague (is it a shower, tub/shower, lavatory, kit. sink or laundry tub faucet) I'd have to say that the flow restrictor in the aerators or showerhead is clogged up. Just unscrew and remove and either clean aerator or sh.head out and/or remove flow restrictor permanently. If that doesn't work turn off water and disconnect supply tubes from faucet and run them into a bucket and turn water back on to check for volume. If you have plenty of water at supplies then remove faucet and take defective faucet back to where it was bought and get another one!
Jun 08, 2014 | Moen & Replacement Cartridge
How to remove flow restrictor from restoration hardware spray jet showerhead
Here is a walkthrough: http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html but you can also just call a someone who specializes in water damage to ask if it is reparable. You can pay someone to do it for you. http://www.allcarerestorations.com/Water-Damage.html
Jan 13, 2013 | Home
I have a Moen single handle tub/shower faucet. I cannot yet get much pressure to the shower head, there is good pressure from the faucet. I have placed the shower head in vinegar with no improvement. ...
Your problem is in the water restrictor located inside the shower head. All plumbing manufacturers install these small plastic internal blockers to reduce water down to 2.5 gals per minute. In your case, this restrictor is most likely filled with sediment which is restricting it even further. Remove the shower head from the curved shower pipe. Look inside where the water goes through it. You should be able to see the restrictor. Maybe you can flush out the sediment. Otherwise, remove it and I'm sure you'll get more pressure then originally installed. Because most restrictors are sort of plastic screens or cones, I usually put a wood screw through the center of this product and then once a few threads bite in, I use a plyers on the head or the screw and pull outward while holding the shower head in a stable position. If you are able to get it out, technically your "out of code" because now your going to get all the water it can really supply.Most people are delighted to have it gone.
Nimsgame
Feb 14, 2011 | Moen & One Handle Tub & Shower Faucet
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
How do you fix hot water shuts off during shower with Model N-069M-OD installed December 2006?
Try flowing more hot water with your shower. During the summer you end up mixing alot of cold water and very little hot water (because your cold ground water isn't so cold in the summer). When you get close the minimum flow rate of the appliance, it will start to short cycle (fire on and off). Here's some recommended things you can do:
1) Clean the shower head - remove scale deposits and or clogging
2) Widden flow restrictor - most shower heads have a flow restrictor on the back of the showerhead; It consists of a rubber washer with a hole in the center. You can widen the hole using a drill bit.
3) remove the flow restrictor - this should be a last resort
Jul 22, 2010 | Noritz 6.3 Gallon Residential Tankless...
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
Water becomes ice cold in the middle of a shower
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
Looking for directions, pictures, on how to change water pump
Water Pump Removal & Installation 3.0L (2V) To Remove:
  1. Drain the engine cooling system.
  2. Loosen the water pump pulley.
  3. Remove the bolt and the nut and position the roll restrictor bracket out of the way.
  4. Remove the accessory drive belt.
  5. Remove the generator.
  6. Remove the bolt and the accessory drive belt tensioner.
  7. Remove the nut, the bolt and the support bracket.
  8. Remove the bolts and the water pump pulley.
  9. Disconnect the water pump inlet hose and the crankshaft position sensor electrical connector.
  10. Remove the bolts and the water pump, and clean the sealing surfaces
To Install:
  1. Install the water pump. Tighten bolts in the sequence shown:
    • Tighten numbers 1-7 to 18 ft.-lbs. (25 Nm)
    • Tighten numbers 8-12 to 89 in.-lbs. (10 Nm)
  2. Connect the crankshaft position sensor electrical connector and the water pump inlet hose
  3. Install the support bracket.
  4. Install the accessory drive shaft tensioner.
  5. Install the generator.
  6. Install the roll restrictor bracket, bolt and the nut.
  7. Install the water pump pulley.
  8. Install the accessory drive belt.
  9. Connect the battery ground cable.
  10. Fill the engine cooling system.
Water pump bolt torque sequence (3.0L (2V) engine)
Jun 26, 2009 | 2001 Ford Taurus
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
