Question about Yamaha Rx-v565 Receiver
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
How to reset my receiver?
    Genius:
  • Yamaha Master
  • 1,054 Answers
Press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Posted on Mar 31, 2015
Testimonial: "Sir Steve, shutting down fixed...but still the "setup" and "options" is not functioning, I cant configure the unit...Is there any way to put it back to factory setting? Thank you"
  • Aldrin Sevilleja
    Aldrin Sevilleja May 18, 2015
    When I press the "tone"&direct" plus "power", it says "NO PROTECT" then after a 2-3 seconds, "1.ANALOG BYPASS" comeout...
    Thank you
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Yamaha RX-v800 av receiver will not power up. Was playing and just shut off & will not powere up again. Was in a stereo/tv cabinet with closed glass doors. Cabinet compartment has vent holes in back....
Mine did the same thing two days ago. No reason to suspect overheat as mine is in the open. Could be the power supply? Mine comes on after sitting for a while.
Nov 18, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Nov 06, 2009 | Yamaha RX-V550 Receiver
Sound quits after 2-3 minutes
bad regulator ic most likely there are several in the set.. I can walk you through it. need to check some voltages
Jul 10, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V660 right channel gone
Try checking the connections.
If your really value your receiver it would worth it.
Jun 22, 2008 | Onkyo TX-DS575 Receiver
Sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
May 29, 2008 | Yamaha RX-V661 Receiver
Hi from the Philippines
as far as DSP surround processing is at question, yamaha will do best but when you ask for audio performance, output clarity and performance.... Denon or HK.
Feb 17, 2008 | Yamaha RX-V661 Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha Rx-v565 Receiver Logo
194 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
