Question about Sewing Machines
It is not stitching regularly. It will hook a couple of stitches then skip numerous stitches.
  • Sewing Machines Master
  • 665 Answers
1. Replace the needle.
2. Check the tension. Tension can cause a real problem if it isn't set properly.
3. Always thread with the pressure foot up. As you are threading give little pulls to ensure there is no snags.
4. To check the timing do this: Move the needle all the way to the left and sew with a straight stitch. Do the same on the right.
5. Was there a difference between the two? If one sewed better than the other the sewing machine will need to be tuned.
Posted on Mar 30, 2015
My singer model 2263 will sew fine then it skips about 3 or 4 stitches. What causes this
needle /hook timing , incorrect needle thread tension or worn bobbin shaft
Mar 29, 2018 | Singer Sewing Machines
Skipping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
May 17, 2016 | Singer Sewing Machines
Skipping stitches?
skipped stitches is usually an indication of timing of hook and needle being off. The needle is not always picking up the bobbin thread. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck. Home
Feb 18, 2015 | Husqvarna Husky 165
Skipping stitches
Skipped stitches
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
Open-toe darning foot skips all stitches....help!
Hmm, have you installed a brand new needle? Make sure the needle is compatible with the thread and fabric. Sometimes a top stitch or microtex needle will work better for free motion quilting or darning.
https://www.superiorthreads.com/education/what-causes-skipped-stitches
https://moonlightingquilts.wordpress.com/2012/04/19/skipping-the-skipped-stitches-in-your-free-motion-quilting/
https://www.generations-quilt-patterns.com/skipped-stitches-driving-you-nuts1.html
Feb 26, 2018 | Kenmore Sewing Machines
Can lint get up inside the shaft that raises and lowers the needle?
the needle bar is not hollow,
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
May 01, 2012 | Singer Confidence 7463 Computerized Sewing...
Skipping stiches in zig zag
This could be caused by several things:
Blunt needle: Have you changed the needle firstly, skipping stitches is a sure sympton of a blunt needle.
Wrong type needle: are you using a regular needle on a stretch fabric, this will cause skipping too, change to a ball point needle.
Timing out: this is the more serious fault, if its skipping after you've changed the needle and sews okay on straight stitch, then it is likely your needle to rotary hook timing is slightly out. Something for a technician to deal with but there is simple diagrams here if you want to take a look at what is involved.
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Oct 24, 2011 | Sewing Machines
Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Oct 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
