Hi i have a 07ev750 lcd tv dvd electrohome that wont turn on !! I plug the power supply on the screen i can see the time but when i pressing the power button nutting happen can someone help me to solv
Hi i have a 07ev750 lcd tv dvd electrohome that wont turn on !! I plug the power supply on the screen i can see the time but when i pressing the power button nutting happen can someone help me to solve it ??? Thx
  • 191 Answers
SOURCE: Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
Posted on Nov 02, 2008
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
Posted on Nov 24, 2008
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
SOURCE: how to reset lg lcd tv
Can't get t v on
Posted on Jan 12, 2013
My tv wont turn off and is flashing colors only
YOU PUT TV IN DEMO MODE, HOLD VOLUME UP AND CH. UP AT SAME TIME PLUG TV IN WHILE HOLDING ALSO POWER BUTTON FOR 15 SECONDS. SHOULD CLEAR.
Oct 31, 2014 | Magnavox 26MD350B/F7 26 in. LCD TV/DVD...
TV no longer power's on. What problem is causing this condition?
If the TV AND the DVD player are not powering on, then it sounds like the problem is at the receptacle or power strip, where the TV and the DVD player are plugged in. Make sure the receptacle or power strip is working. Plug something else in, a lamp, a radio, anything, and see if it works. If it doesn't then the power strip is off or not working or the wall receptacle is not working.
May 25, 2014 | Coby TVDVD2050 20 in. TV/DVD Combo
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
After you turn it on it goes to a black screen, then wont turn off.
first check the supply of the LCD monitor check the plug supply usually 110V or 220v use a voltmeter, if the voltage is present look for the indicator lights that is changing when power switch is press,the indicators tells you if the problem is in the power supply area of the LCD monitor or in the screen, usually the problem with the LCD monitors is in the screen check the bulb on top of the monitor check if it is not function well this bulb is responsible for the brightness of the screen if it is defective replace it or maybe the supply of the bulb is defective you can use the power supply of the cathode light as a replacement to its supply that is usually use in motorcycles signal lights.. hope this helps you..
Jul 25, 2011 | Coby 40 TFTV4028 LCD TV
LC3760N power light blinks
Replace the whole board,LCD usally the IC is dead,not like DLP the capacitors,burn most of the time.
Sep 22, 2009 | HP LC3760N 37 in. LCD HDTV
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Tv wont turn on, i got it last april, it worked eversince,
First off, try a power drain:
Unplug the TV's power cable so it is not grounded to the house.  Then press and hold the TV's own power button in for a minute.  Plug the TV back in and see if it works. If it sill won't work, are there any visible LED lights you can see in the back of the TV?  You need to determine if the TV's power supply is shot or the TV's mainboard.  Service would likely be required if the TV still won't turn on.
Mar 24, 2009 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
Tv turns off
Hi there, my husband fix the problem. My small son had changed the settings for the HDMI. My husband switched the tv to DVD mode started a dvd & changed all the settings back. After changing all the settings he also reboothed the setbox machine.
Apr 11, 2008 | Samsung LN-S2651D 26 in. LCD Television
Code needed for a Electrohome tv
The Product: Electrohome 27E510
The Problem:
3rd Party Universal Remote when trying to "scan" for correct codes inadvertently activates a diagnostics setting on the TV set.
The Symptoms:
The word "FACTORY" appears on the upper left quadrant of the screen in RED letters & suddenly all controls are "Locked Out." Television will not respond to button presses on original remote or on it's built-in-buttons on the side panel. All settings/options are "Locked Out" & the TV can only be shut OFF by physically unplugging it. Additionally, when the TV is plugged back in, it is still in the "ON" state & remains in "Locked Out" state.
The Solution: (thanks to a couple of hard-working Support Personnel at NESA)
Plug TV back into power source. Wait until it powers up and the word "FACTORY" is visible on-screen.
Press 6-4-8-3 on the TV's ORIGINAL IR remote device.
You are now in the diagnostic settings Sub-Menu, & the word "ADJUST" will be on the screen.
Press "MENU" on your TV's ORIGINAL IR remote device.
The TV is now back to it's former fully-functioning state.
Dec 28, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
