Question about 2001-2004 Toyota Sienna Saddleman Leatherette Seat Covers 779264-14 - Leather
Check light is flashing.What does that mean? - 2001-2004 Toyota Sienna Saddleman Leatherette Seat Covers 779264-14 - Leather
  • Denise Cannistraci Jun 04, 2015
    could just be the mileage has gotten to say 30, or 40 thousand miles and lite will trip to ensure you go in for service that is due at that time.
  • 3,462 Answers
Check light for what please. If it is for engine you should check toyota forums
Posted on May 29, 2015
My engine light is on first it is solid and then it flashes ...what can this be
When a check engine light is on it means there is a problem in the obd 2 system that is causing the vehicle to be outside federal emissions 1 an a half times an there is a DTC - diagnostic trouble code stored in the ECM / PCM -engine computer .
A flashing check engine light means there is a 'class A' misfire that is present. This type of misfire WILL ruin the catalytic converter(s), if the problem isn't fixed in a timely manner.
Mar 18, 2015 | 2003 Chevrolet Chevrolet TrailBlazer
2002 Chevrolet Blazer won't accelerate past 30mph
A flashing check engine light means the engine is misfiring. This flashing light will eventually set a code in the low 300's. When you get the code it will tell you which cylinder. If you get a straight 300 it means multiple misfires. Right now if the light is only flashing, check the secondary ignition for loss of integrity. It's more than likely there. I hope this helps.
Mar 29, 2014 | Chevrolet Blazer Cars & Trucks
Check engine light flashing on idle 2007 hyundai accent and sputtering. Previous (2 months ago) P0496 code caused steady check engine light. Some roughness noticed when accelerating steady below 60 km per...
Dont drive a car with the light flashing. A flashing check engine light means that something is really wrong and you can damage the engine if you drive it.
Nov 04, 2013 | 2006 Hyundai Accent
2002 dodge intrepid sxt 3.5l. what does 10 flashes of check engine light mean?
Are you sure is not 5 flashes with a short pause in between and then 5 more flashes? Code 55 indicates the end if the diagnosis.
Mar 02, 2013 | 2002 Dodge Intrepid
When the check engine light is flashing it means that the computer has detected a misfire in the engine.It is not good to drive a vehicle that has a flashing check engine light; one or more sensor in your vehicle is advise about an code fault. I suggest scanning for know what code is in there and solve it.
In some vehicles, a red check-engine light means the car needs absolute immediate attention while a yellow check-engine light means you need to make an appointment soon. The light is used to indicate PCM (Powertrain Control Module) problems that are associated with your vehicle's emissions system.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 01, 2011 | 1997 Pontiac Grand Am
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
I have a 95 honda accord check engine light flash 1 long and 7 short. what does that code mean?
That means Code 17, one long flash means 1, seven short flashes means 7. The code is for the Vehicle Speed Sensor (VSS) Have it checked and replaced if necessary.
Jun 13, 2010 | 1995 Honda Accord
What do the warning lights on the 2004 VW Passat dashboard mean as they are a few flashing and I don't know what they mean?
Depending on which light is flashing will determine whats wrong, normally thee are three lights that flash one is yellow check engine light, when it flashes it means a misfire and catastrophic catalytic converter failure. Red oil light means your low on oil and if it does not have a gage you may have damaged the engine and then there is several others like air bag warning light this would be caused by a defective clock spring, or a malfunction in the computer system. Your best bet is call your local dealer and describe to them your problem and tell them what lights are flashing they can determine weather you should drive it or have it towed in for repairs. Remember FLASHING RED OR Yellow light means imminent failure of expensive engine parts.
Jan 15, 2010 | 2004 Volkswagen Passat
Check enggine
Do a self test. Turn key to on position and back to off position 3 times. a series of flashes will commence from the "check engine" light. The first set of flashes is the 1st digit of the code, then there will be a pause, then a 2nd set of flashes, This will be the 2nd digit of the code. For example, 3 flashes, pause, 7 flashes, means code 37. Check what the code means in a Haynes auto repair manual. This will tell you what the engine light on your car means.
Jun 12, 2008 | 1998 Jeep Cherokee
2001-2004 Toyota Sienna Saddleman Leatherette Seat Covers 779264-14 - Leather Logo
Top Saddlemen Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Saddlemen Vehicle Part and Accessory Expert? Answer questions, earn points and help others
