077-909, Paper detected in paper path at power-on. what should I do
  • 208 Answers
SOURCE: Paper jam message
A couple of things.
On the left side of the paper path, there is a registration flag type sensor that a small piece of paper can be torn off on.
Also, if the paper has been caught on that flag, it may be broken.
Carefully look with a flashlight for just a corner of a piece o paper left in the machine.
I suspect possibly the flag has been broken on the registration sensor.
Posted on Dec 04, 2007
SOURCE: Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Posted on Mar 31, 2008
  • 2692 Answers
SOURCE: Paper Jam detected. None found.
Here is the Xerox support page for your printer. It even has a movie on removing paper jams.
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8400&country=United%20States&language=en#_manuals_and_documentation_
Posted on Jan 04, 2009
  • 13433 Answers
SOURCE: paper jam
try this....
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
aicaxz
  • 511 Answers
SOURCE: Epson R265 paper feed problem
Paper feeder problem. You must open case and paper feeder.Check for all screw. spring, rubber and lubrication. If you never done, find diagram at printersiam.com. is printer paper jam berfore? and clearing jam by pulling paper form back?
Posted on Jun 29, 2009
200.13 paper jam check cartridge
The unit has either an electronic sensor or actual switch to detect paper path. If there is more paper dust than usual, visually check for any thing that me impede the paper. If you are using recycled paper they seem to create more dust due to the clay in the paper. If you have canned air blow out as much dust as possible or if you have computer vacuum, vacuum the interior. If there is a flag type sensor in paper path be careful not to knock off spring. Hope this offers some help.
Mar 03, 2014 | Lexmark "x652de multifunction monochrome...
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Paper wrapper up in paper jam. Unwrap it but when push it on still says PAPER JAM but can't see any paper
Along the path that paper travels inside the printer are several sensors, and these sensors detect the presence or absence of paper. However, often times either bits of paper or accumulated dust will get trapped on top of these sensors, and thus they will detect a false paper jam. In order to remedy this situation, take a thick piece of card stock and manually pass it through the paper path. Then, if available, blow some canned air inside the printer along the same path. After that, open and close the front lid and see if the problem is resolved.
-David.
Oct 30, 2010 | Brother HL4040CN Laser Printer
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
My printer is saying that there is a paper jam but there is nothing in there. what can i do?
there a small plastic sensors on paper path, normaly you have some sensor stucked.
you can check all paper path inside printer, there is a paper door nearby power input. open-it and locate the sensors small plastic finger check for free mooving operation.
normaly is one of three sensors (one for no-paper, 2nd for middle of paper path and one for paper position nearby print-head, test path with a paper, for free path.
Dec 11, 2009 | Canon PIXMA MP240 All-In-One InkJet...
After each copie the lights of jamed paper and the first bac of paper are display and i can'tcopie whithout clearing them
1-please check the paper path for any foreign objects droped inside(like pins)or any small pieces of torn paper.
2-check all paper detecting switches for free actuation and nothing prevent it from paper detection.
Nov 28, 2009 | Sharp AR-M205 Copier
Cannon printer pixma mp470 paper jam
hmm, could you be more specific?. But I'll try to solve anyway
Paper jam error occurs because:
  • Paper end not detected by paper sensor; set paper properly and press Stop/Reset button
  • Paper sensor broken; replace paper sensor
  • Drive assy broken; replace drive assy
But before it all please check if any broken paper or another material is in paper path blocking the paper to reach paper sensor.
Nov 09, 2008 | Office Equipment & Supplies
Printer says paper jam, but no paper in there
use a flash light check all paper path, specially the area around the toner. all you need is a small piece or other (dust). There is a micro switch that detect the paper travel. so if anything preventing the switch to open, you will get error message.
after that, open the toner door, reseat the toner and close the door. the pirnter should return to normal.
Oct 23, 2008 | Enlight Intel Xeon 470 WATT EN-470 MP...
Paper Jam
1-fan the papers many times befor you put in the machine.
2-keep the paper inside its cover in dry place.
3-check for any foreign object droped in paper path(pins-a small pieces of torn paper).
4-check for good condition of paper detecting switches in paper path inside the machine.
Jun 19, 2008 | Canon FAX-L350 Plain Paper Laser
k24674
jasbo
jasbo
