Question about Cell Phones
I dropped my moto E phone in a bucket of water now it will turn on but won't slide the screen to unlock what do I do? I can't afford a new phone or repairs...
    Genius:
  • 1,056 Answers
You can try removing the battery and put the phone and battery into a jar of uncooked rice for a couple of days. The rice will draw moisture away from things. This fix may or may not work but it is a trick worth trying. I've done it before and it did work; difference is, I did it within minutes of getting the phone wet. Other wise it will be replace the phone.
Posted on Mar 30, 2015
  • Coss Mar 30, 2015
    Found another option I didn't know about before; from the reviews on it, it looks like it really does work. It's bu Kensington, called the Evap Pouch. You can get a multi use one for about $15
  • Coss Mar 30, 2015
    http://www.amazon.com/Kensington-Rescue-...
5 Suggested Answers
SOURCE: MOTO Q DROPPED IN WATER
well one thing you should always remember is to try and clean an electronic device with alcohol ,never turn on the phone right after the incident,the problem most of the times is the hardware and not the software as far as i know.
Posted on Jul 20, 2008
SOURCE: can't get my sciphone to slide to unlock
use a pen and slide it slowly
Posted on Jul 30, 2009
  • 93 Answers
SOURCE: touch screen does not work. the phone will ring,
Digitizer failure. If its under a year old it should be covered under warranty. If not - Check out Cellphonerepair.net
Posted on May 02, 2011
ashlocked
  • 1140 Answers
SOURCE: I dropped my iphone 3g
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Posted on Jul 21, 2011
How do I fix my Motorola Moto G after it has dropped into water?
if you immediate removed the battery and left it drying for a few days you had a chance. but now it is fried
Jun 21, 2015 | Motorola Mobility Moto G 8 GB Black...
I dropped my Moto G and now the screen will not work. What do I do to restore it back to working order?
Erin-
If the LCD is broken then it won't work. If the glass is broken but the LCD is fine it should work but isn't safe. You can visit our site CONTACT US for repair options.
Mark
Motorola Support
Feb 25, 2015 | Motorola MOTO G XT1034 8GB Unlocked GSM...
The fone was dropped in water for no more than cpl seconds...it was left to dry overnight and nxt day when switched on it powered up as normal.. however the screen has been totally unresponsive to touch...
Take battery out of phone and let set overnight in a dry area such as oven. I have turned oven on to warm and then turned oven off and let phone set in there overnight with battery out of phone and back off of phone and then replaced battery and restarted phone and it did work again. Rich
Dec 20, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
My HTC Incredible Won't Swipe To Unlock Screen
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 06, 2012 | HTC Droid Incredible Cell Phone
Unlock nokia 6500 slide
It is very simple to unlock a cell phone!! You can unlock your Nokia 6500 Slide using unlock codes and you can get it from either your service provider or from any online sites. I unlocked my phone at Theunlockarena.com , the unlocking steps were simple and the codes were affordable.Check it out!!
Aug 01, 2012 | Nokia 6500 Slide Cellular Phone
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Jul 21, 2011 | Apple iPhone Smartphone
My iphone 3g 8gb seems frozen, on my main screen it says slide to unlock, well it won't slide to unlock, ive turned it on and off again and done the reset thing but no joy at all, does this mean my...
try the new update that just came out today , sync your phone in itunes and then install the new update on the ios software . hopefully this works
May 05, 2011 | Apple Cell Phones
My palm pixi screen is black and will not turn on. I have tried plugging it in, unplugging it, and pushing the power button (both for a long time - until I hear the phone make a sound, and as a quick push,...
Hi, problem can be solved.
Palm pixi cell phone has both a sliding phone and a straight phone.Which is yours?
Sliding Palm Pixi phone with a black screen is always caused by a thread like object inside the phone.
These threadlike object is connected to the phone board and is also connected to the screen. (makes the screen display). When it gets damaged or has a cut due to sliding of the phone, it makes the screen go black.
Straight Palm Pixi phone with a black screen can be caused, when the phone of the screen is damaged,might not be by the phone dropping on the flow,it might be an internal damage from factory (factory default).
I would advice if the phone is on guarantee,you can take the phone back to where you purchased the phone from fro them to replace it with another one.
Butplease,make sure you don't Tammper with the phone,sothat they can be able to replace it without any damage.
Hope ti helped
Thanks for using fixya.....
Jan 05, 2011 | Palm Pixi Cell Phone
Iphone dropped in a pool help. Put it in rice for a week and it will turn on but will not allow me to slide it to unlock
Ok. What let you slide content and do so many things through touching the screen of your phone is the "capacitive touch screen" embeded on the phone itself has shorted out when it felt in the water (bear in mind that it functions through electricity that continously runs through it. You should contact somebod who knows how to replace it. Good luck
Jan 03, 2010 | Apple iPhone 3G
I dropped my iphone and now the unlock slide doesnt work
It looks like you need a new LCD/digitizer which you canreplace yourself. Here's a guide on how to disassemble an iPhone. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party iPhone Repair Services.
Mar 18, 2009 | BoxWave Corporation Apple iPhone 2G...
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
