Question about LG Washing Machines
My lg front load direct drive washing machine power on do a load of laundry and when its done there's no power the machine will not power on . I have to unplug it wait a few minutes then plug it back in for it to power back on.
  • LG Master
  • 5,323 Answers
CONTROL BOARD?
Posted on Mar 30, 2015
  • 185 Answers
SOURCE: Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Posted on Mar 28, 2008
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
  • 4 Answers
SOURCE: LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Posted on Oct 13, 2008
gdmisp
  • 66 Answers
SOURCE: no power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Posted on Jan 15, 2009
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
Whats a good discount site for LG front load washing parts.
I used Encompass to order LG parts at http://www.encompassparts.com/ . LG Canada does not provide parts directly to consumers, and therefore had to order from Encompass in the US on several occasions. I am not sure if they are best from a discount perspective, but they are very helpful, and I have not had any problems with their service or parts.
Jan 18, 2015 | LG WM2077CW Laundry XL Front Load...
No power to the lg washing machine
This is a hard problem to diagnose remotely. Someone has to have a look at the machine, as any number of electrical/electronic failures could cause a loud popping noise. I would recommend a service call.
Apr 14, 2014 | LG WM2077CW Laundry XL Front Load...
When the wash has been done, and UE comes up, what does that mean?
Hello
Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Move the washing around inside the washing machine to create a more even distribution of weight
Apr 01, 2011 | LG WM-2277HW Front Load Washer
My LG Wm 2432HW is making a lot of noise when it goes into the spin cycle. Is there an adjustment for the direct drive gears? The machine is level and it occurs with any load of laundry.
check your the inside tub for play if the tub moves up and down or side to side loosely your bearings are possibly going out. mine did that and it wasn't long before it ground a hole in the outer tub causing a massive leak.
Nov 05, 2009 | LG WM2432H Front Load Washing Machine
Oct 10, 2008 | LG WM-1832C Front Load Washer
Lg wm2277hs
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Washing Machines Logo
66 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
