Question about Pool & Spa
Keeps coming up prime failed - Pool & Spa
    Genius:
  • 1,056 Answers
Please help us to help you; without knowing the year make and model of your pump any help someone would be able to offer is a guess, or information that does not apply to your question.
Posted on Mar 30, 2015
HOW DO YOU PRIME THE KERIG
Remove the water reservoir, then reinstall it to it's normal position. Refill or top off with the recommended bottled or filtered water to the max fill line.This will clear the prime message. If after you do the the above procedure at least two times, the prime message keeps coming back your machine has brewed its last coffee. If you bought it from Costco, I would recommend returning it there. Or If still within the 12 month warranty period, call Keurig.1-866-901-2739. Tell them and they will ship you a replacement.
Oct 11, 2014 | Keurig Platinum B70 Coffee Maker
My digital says to prime the machine
Lift the water reservoir up then reseat it. This will clear the prime message. If it keeps coming back your machine is dead. If in the year warranty call Keurig. They will ship you a replacement.
Jul 31, 2014 | Keurig B60 Coffee Maker
Keeps saying prime. I've unplugged and restarted, refilled resevoir.
I unplug the unit and it reset. The Prime light went off.
I unplugged mine and the unit reset and the Prime warning went off
Http://www.buyicemachines.com
Feb 28, 2012 | Keurig B60 Coffee Maker
MY PRIME LIGHT KEEPS COMING ON --I HAVE FOLLOWED THE INSTRUCTIONS IN THE BOOK BUT IT KEEPS HAPPENING
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
Prime light keeps coming on
please resubmit with your make and model...also is this a prime light on the front of the vacuum?
How often does it keep burning out? Any smells?
Mar 06, 2011 | Vacuums
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
My pump keeps trying to prime then alarm comes on and states clear drain
make sure top on ok if ok check intake union maybe loose its sensing a obstruction
May 20, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
My Saeco Royal Coffee Maker keeps giving me a ventilate message and wont do anything else. What is wrong? And how can I fix this?
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. Hope this helps , Lee Davidian
Dec 27, 2009 | Saeco Royal Digital Plus Coffee...
Keeps blowing the prime fuse under hood,gas gage won't read,heated seats won't come on,after truck starts,blows that fuse each time.Problem just started.
this problem is most likely caused by a fuel pump with high amp. draw on start up.use a amp meter.then replace fuel pump.
Oct 23, 2009 | 2003 Chevrolet Silverado 1500
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
