Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch SHU5305UC dishwasher stuck on one minute while still rinsing, do you have a service manual?
The water is hot so the heater is working. The drain pipe is clear and the drain pump is OK.
    Habit-Forming:
  • 20 Answers
Yours might be under recall http://microsites.boschappliances.com/safetyrecall/dishwasher/popup_ModelList.aspx you might have a bad control board
Posted on Apr 12, 2015
Testimonial: "Thanks Erica, but I ended up ordering the service manual and figured it all out. It was the water inlet/drain module that was clogged, and the only way to figure that out was to take it completely apart. On the issue of the recall, yes, you are right, but I faced this problem last year, and upon checking the main control unit's circuit board, I discovered a bad solder on one of the solenoid pins, that obviously happened because there was too much overheating from a bad-design pad, unable to handle the current load. I increased the copper area of the pad and re-soldered the pin of the corresponding solenoid, and all there has been working perfectly ever since. So much for having to wait for a recall freebie replacement board from Bosch! I hope my info will help others having this same issue."
  • 125 Answers
SOURCE: Bosch dishwasher stuck on "1"
YOU MAY NEED A CONTROL BOARD OR A HEATER. THERE IS A CONNECTOR WITH A RED AND GRAY WIRE, THE RED WIRE IS THICKER THAN THE OTHER RED WIRES. IF YOU HAVE 120 VOLTS ON THERED WIRE THE CONTROL IS GOOD. YOU NEED A CLAMP ON AMP METER TO TEST TO SEE IF THERE IS AN AMP DRAW ON THE RED WIRE WHICH WOULD TELL YOU THE HEATER IS WORKING
Posted on Feb 07, 2008
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
fphandyworks
  • 56 Answers
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Posted on Jan 05, 2009
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
My boosh dishwasher is stuck in rinse and wont drain, but when i press cancel on the washer the water drains.... whats causing this????
There is a chronic problem with Bosch dishwashers where the heater relay is soldered to the printed circuit board becomes loose (actually it seems like the solder just disappears from the connection).
You may also note that the timer seems to get stuck and will not advance.
Remove the top front panel, the circuit board is on the right side as you face the dishwasher. You need to re-solder the heater relay terminal.
May 26, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
Bosch Dishwasher will not dry dishes, washing is fine. Model SHU43C05UC / 17. About 4 years old. Cannot find the manual. Any help is appreciated.
Bosch dishwashers do not have built in heated dryers. Be sure your water is hot enough and the rinse aid dispenser is not empty. The Bosch should heat your water to a minimum temp and if it is not, this could be your problem.
Ken
Oct 25, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Clean dishes are wet
1)please check the rinse chemical passing correctly.
2)check the boiler heater working.
Jan 08, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My dishwasher also gets stuck at 1 minute and it keeps on going and going . I had to turn it off. I called up bosch and they told me to hold the power and the rinse and hold button for 5 seconds but it did...
well basicly the technicien came and knew nothing - he tried a few things so he is alreadyto change the electric board and we all know how expensive that is - any way he left saying he will come back today with a new board  - after he left i went and turned off the breaker to the dishwasher for  5 minutes which is what bosch told me to do - then i pressed power and rinse and hold for 5 seconds and then it drained all the water i turned the power off - then on again pressed my cycle ( which I always put delicate/econo and it started - but it showed 2 hours so i figured it must be the board - but as it was going through the cycle it seems the time was adjusting itself and it went through the usual amount of time - all the way to the end - it did not get stuck at 1 minute this time - so I hope it has fixed itself - I will see with the next load if all ok - thanks take care - the bottom line is My husband had started the dishwasher the other day and he must of pressed all kinds of buttons and messed up my machine -
Jun 11, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch SHU3300 dishwasher stuck on hot water intake (w/ no power)
It sounds like the fill vlave is stuck open. This can happen if your pressure is low or if the machine is old. I would start by replacing the vlave.
May 12, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Describe your Bosch 24 in. SHU5305UC
please post me your email i can send you in PDF format the manual so you can fix it yourself. There are prem chat avib but this part is free but you have to do the work If you want us to give you step by step instructions on how to fix it you will have to pay
Oct 22, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher keeps running
I have seen this several times, and all of the times it has a bad control board. usually if you take the control board out, you can see a visibly burnt spot on the back of it wher a connection has melted. Another possible slowrun time problem could be that the water coming into the dishwasher when it fills is not hot. If it isnt hot, it takes the dishwasher longer to heat the water to temp, and therfore it runs longer. Is the water coming out of your tap reasonably hot? if not you may need to turn up your water heater settings. But if nobody has messed with the water heater, or the tap where the dishwasher is attached and the problem just started then thats probably not it. Good Luck!
Aug 04, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
128 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
