Question about Transmission & Drivetrain for Ford Ranger
Transmission Shifting Problems When Cold
I have a 1993 Ford Ranger and when it's cold the transmission doesn't want to shift from 1st to 2nd, 2nd to 3rd, etc. After a half a mile or so it changes and is smooth the rest of the day. Any ideas?
  • 774 Answers
Hi,I had a simulare problem with my car,I had to wait untill the cold start had switched off then I could drive it,if I tryed to drive before cold start switched off it would hold on to the gears untill high in the reves.
I changed the fluid and filter and the car changes now.
I know no two problems are the same,so food for thought,
and all the best.
Posted on Mar 30, 2015
My 1999 ford ranger shifts hard from 2nd to 3rd gear what is the problem I recently changed fluid and filter but shifts hard !
Auto Trans not shifting correctly from 2nd to 3rd - Ford Explorer ...
www.explorerforum.com > ... > Under the Hood
May 8, 2004 - 19 posts - ‎9 authors
Auto Trans not shifting correctly from 2nd to 3rd Under the Hood. ... Become an EliteExplorer. Lithuania. 1999 5.0. Join Date: Jun 2003. Posts: 107 ... When this happens, the transmission will skip to the next gear like you said.
Transmission Harsh shifting - YouTube
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
... Doctor, explores the causes of harsh shifting in automatic transmissions. ... Early diagnosis is important to ...
Hard Tranny Shift between 2nd & 3rd - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Feb 24, 2012 - Hard Tranny Shift between 2nd & 3rd Super Duty & Heavy Duty. ... I just got a new to me 99 f250 5.4 V8 SD XLT 4x4 Auto Trans longbox 118k miles. ... it out and said it was solid except for a hard shift between 2nd and 3rd gears. ..... Hard shift between 2nd and 3rd, Brenda Lamka, Explorer, Sport Trac, ... hard shift 2nd to third gear only 4r100
Dec 26, 2012
hard shift into 3rd
Nov 4, 2009
4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK ...
Mar 15, 2007
00 Expedition trans shifts late and hard
Jan 01, 2016 | Ford Cars & Trucks
2001 BMW 318 does not shift into 2nd when cold
I would start by replacing the transmission fluid, that will likely resolve the issue.
Jun 30, 2013 | BMW 318 Cars & Trucks
Can a bad thermostat cause a transmission not to shift properly in a 2002 chevy impala?
It is absolutely possible for this to be the case. When the thermostat is not reading the temperature of the coolant properly, the engine ECU or computer will sometimes not allow the transmission to shift either correctly or at all. I have a ford ranger that will not shift into overdrive on cold days until the engine has gotten up to a warmer temperature. This is because the ECU is limiting the transmission from shifting into overdrive while the thermostat is still registering cold temperatures. Now if the transmission is shifting rough or randomly, that could be another problem like a shift solenoid inside the transmission. But as far as your original question, yes a bad thermostat can definitely be a possible reason for a transmission not shifting "normally". Hope this helps.
Mar 06, 2013 | 2004 Chevrolet Impala
Having problems engaging 1st & 2nd gears when cold any one have any ideas thanks
have transmission fluid and filter changed.most time if transmission not shifting good when cold,transmission filter could be stopped up and fluid thick old nasty burned not circulating good cause some slipping in transmission.
Sep 29, 2012 | 2001 BMW Z3
2000 Jeep Grand Cherokee shifting problem from 2nd to 3rd
Check the kick down cable. If it sticks the transmission won't shift. I sprayed WD-40 on both the top and bottom connectors , and it worked like a charm. It's alot cheaper them spending 2000 on a new transmission you don't really need.
Oct 30, 2009 | 2000 Jeep Grand Cherokee
Having problems with the transmission shifting irregular between 2nd and 3rd
The ford taurus is know for having a weak transmission, however if the transmission is serviced regularly you can avoid problems.
May 05, 2009 | 2003 Ford Taurus
Transmission shifting on 2001 Ford Ranger
That sound means the transmission fluid is dirty. Go to a shop and get a BG Power Flush.
Jan 02, 2009 | 1991 Ford Ranger Supercab
1992 tracker automatic transmission shifting
I have the same problem also. Hope someone has the answer.
Oct 07, 2008 | 1992 Geo Tracker
I am having problems with my ford focus 2001 with 121,000 I had the transmission filter changed a week ago and the system flushed. But it still seems to be having problems shifting from 1st to 2nd gear...
It very well could be a faulty shift sensor, ford is bad about putting these sensors internally on the transmission. I would reccommend taking it to a shop with the proper computer so they can go into the vehicle's computer and test the shift solonoid in the transmission. If that is working probably, the clutch between first and second gear could be getting a little wore out, once it heats up it swells up and could be acting properly then.
Aug 07, 2008 | Ford Focus Cars & Trucks
Transmission & Drivetrain for Ford Ranger Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
