Question about Ryobi Garden
Hi there how to put a piston rings on a piston of a ryobi brush cutter 41cc engine.
  • Hubert Hayes
    Hubert Hayes Apr 25, 2015
    Open head , the piston should be sitting tottally free by it's self, replace your rings, Take a radiator hose clamp that is big enough to fit over the piston and loosely tighten it around the piston to hold the rings in, then slowly tap the head down over the piston. When the piston is in then take the clamp appart and remove it, once you have done this put head back into place.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You're asking about putting the rings on the piston
or
putting in a new piston and rings
I wouldn't suggest doing either
Posted on Apr 28, 2015
  • 2,210 Answers
If you don't have the knowledge or experience get a good DIYer or small machinery / garden machinery mechanic to look over your shoulder when you have a go. Its not a job for the untrained as there are precise items to assembled.
Posted on Mar 30, 2015
  • 148 Answers
SOURCE: Need a manual for a RYOBI Model RY30530.
go to www.managemyhome.com and download a free copy of the manual.
Posted on Jul 16, 2009
  • 130 Answers
SOURCE: BAD STARTER
it might have a easy start that wound make it seem like its sliping.change spark plug and gap at 030.see if it helps if not rebuild carb.
good luck
Posted on Jul 21, 2009
  • 52 Answers
SOURCE: Just got a Ryobi brush cutter, but no
Use 4 ounces of 2 cycle oil in one gallon of gas.
Posted on May 04, 2010
Testimonial: "Thanks, a lot! I didn't want to ruin it with the wrong mixture. Your answer was prompt and clear!"
  • 183 Answers
SOURCE: I have no spark on my Ryobi Brush Cutter.
If the spark plug you have put in has the correct gap then u will next have to check or change the HT lead Change it if no spark is showing
Posted on Jul 29, 2010
rycgl
  • 1545 Answers
SOURCE: the pullcord has come out
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Posted on Feb 02, 2011
Hi,My Ryobi 30 Petrol with Brush Cutter attachment has so much vibration I cant use it..
This is likely a mechanical problem caused by either 1. A serious imbalance with the cutter attatched to it 2. The engine is failing and the main crankshaft bearings are worn causing crankshaft "wobble" setting up the heavy vibration you speak of.
Aug 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have a makita backpack petrol strimmer fitted with a line head can i fit a brushcutter blade instead i donot have the full model No it is a 41cc engine it is an early model
Hi Doug,
There are adapters for just about every combination of trimmer, brush cutter blade, grass gator, etc. you can think of.
One of the most handy purchases has been a non specific arbor adapter set. Not only does it have 2or 3 each of the most common nuts in both left and right hand thread, it has inserts that keep every blade, flail and brushcutter I've tried dead center.
It even came with a diamond shaped one for a skillsaw blade that I tried with my Ryobi 4 cycle. That thing turns thorny blackberry vines to powder.
So the answer is yes.
Best regards
Aug 14, 2010 | Garden
Arbor stuck on gear head/bc26
I have the same problem. Any solution?
Apr 20, 2010 | Ryobi Garden
I have no spark on my Ryobi Brush Cutter. Replaced spark plug but still no spark.
Apr 20, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have a ryobi brush cutter rbc 40sb the pull start is not conecting to the engine i need a complete pull start can you tell where i can get one please regars gary dodd
Hi there
A chainsaw or small engine repair shop may have the part.
If not, Click here for the Ryobi Service center locator page. Just enter your zip or area code and it will display a list of the nearest Ryobi service centers.
Hope you find this very helpful
Best regards
Mike
Nov 24, 2009 | Ryobi Garden
How so you replace flywheel on ryobi brush cutter?
If you dont have a piston stop to screw into the spark plug hole try feeding a lenth of starter cord into the hole then turn the engine over until the piston stops at the bunched up rope, hope this helps
Sep 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I can't restart my Ryobi cutter once it's been running.
This is because Ryobi uses a loose fit on their piston and cylinder. As the cylinder heats up it grows in size causing the compression to drop.
when the cylinder cools the cylinder shrinks and you regain your compression.
Another possibility is that you are boiling yoour gas causing a vapor lock. This also goes away once the unit cools.
Sep 10, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
The fuel line leaks coming out of the plastic fuel tank on my Ryobi Brush Trimmer (990R I think). I am replacing the old plastic fuel lines into the tank but noticed that they are a little loose too. Any...
There is a little white ring that goes over the line and into the opening on the tank. This is what seals the line so the gas won't leak out. They are about $1.00 at any small engine service shop.
May 15, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
240 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
