Question about Dyson DC33 Multi-Floor Upright Bagless Vacuum Cleaner
Why won't my vacuum adjust to my new carpet height? We recently got new carpet and it has a higher pile than our old carpet. When I put the setting to carpet it
I'm not possible that I've designated the right DC33 -- but I'm pretty sure...
    Genius:
  • Dyson Master
  • 1,244 Answers
There is no way to adjust the height of your model.
Posted on Mar 30, 2015
Powerhead won't rotate on low-pile carpet
Sounds like the vacuum is adjusted too low on the carpet. Adjust it to a higher level. If this is not the problem, then the belt is slipping. Buy a new belt.
Dec 02, 2015 | Hoover Vacuums
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
We had an older dyson vacuum that worked great until it had to be replaced and now our new one it works great on short carpet but is very difficult to push on thicker carpet.
Hi Ronnie, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your new Dyson vacuum on this particular type of deeper-pile carpet. It's possible your new machine has higher suction at the cleaner head, and this could mean it needs slightly higher push-force on certain carpets with deeper, denser pile, or thick underlay. You may find it helps to use the vacuum with the brush bar switched - carpet manufacturers will sometimes advise vacuuming deep-pile carpets in this way.
However, I would encourage you to get in touch with us directly so we can take some further details about the issue. When you have your Dyson vacuum easily to hand, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to discuss your concerns.
We'll look forward to speaking with you.
Jun 03, 2015 | Dyson Vacuums
What does turning the nobe for the twister do whats the purpose
It is a height adjustment to compensate for higher or lower carpet pile.
May 06, 2015 | Vacuums
How do I adjust the power cam locationpower cam on a dc27
Hi Charles, it's Jack at Dyson.
DC27 is engineered to adjust automatically for different floor types - there is no way of manually adjusting the height of the wheels or brush bar. The vacuum may need higher push force on certain types of deep pile carpeting. We would recommend checking directly with the carpet manufacturer for their advice on caring for this particular carpeting - manfacturers may recommend vacuuming some carpets with the brush bar turned off, and it may be worth giving this a try.
To turn off the brush bar, just use the brush control switch next to the red on/off switch:
Jun 19, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
We love our Dyson DC25 Animal but we just got new carpet and it's like pushing furniture around the room. I know it doesn't have a height adjustment but is there any other option?
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your DC25 Animal on this particular type of carpeting. This sounds unusual especially as it worked effectively on your older carpeting. As DC25 is engineered to adjust automatically to different floor types and pile heights, there is unlikely to be an issue with the vacuum itself.
It may be worth checking directly with the carpet manufacturer for their guidance on caring for this specific type of flooring. Manufacturers will sometimes recommend vacuuming certain types of long-pile or delicate carpeting with the motorised brush bar turned off.
If you'd like any further guidance from our experts, you can reach us by calling the Dyson Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 11, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Wont move forward or backwards
Generally the belt is probably stretched and needs replacing but I have had several that required modifying the height adjustment assembly. Belt should be a bit of a fight to stretch and get the brush block back in properly to maintain resistance. The higher carpet causes the belt to slip and can even cause burn/wear from the motor shaft spinning in one spot. Sometimes people run them and burn through and break the belt. Generally you smell rubber burning if belt is slipping and burning. The height adjustment modification was a last resort and not easy! Not for the average person! Another post tells how to modify but better be handy!
Dec 07, 2013 | Hoover Vacuums
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Kirby creating dirt under carpet?
It is possible that the height adjustment on your Kirby is to close to the carpet,which could account for the problem you're having.The correct height adjustment for your Kirby is this-Lower the height adjustment down until you hear a change in the sound,then adjust one more click down.The Kirby is at the correct height for cleaning.If the carpet is different in another room,adjust it the same way for each carpet
Dec 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Can I fix height adjusment?
all i no is on the bottom of unit there is 2 smaller wheels that control the height adj. see if that the prob.
Mar 01, 2008 | Hoover U6434-900 Bagged Upright Vacuum
Dyson DC33 Multi-Floor Upright Bagless Vacuum Cleaner Logo
390 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
