Question about Miele T8005 Tumble Dryer
The door shuts and the screen says close fluff door even though it is shut and clicked in
Will not allow any further progression
  • Miele Master
  • 4,018 Answers
Switch is damaged happens a lot you will need to replace the switch.
Posted on Mar 30, 2015
Testimonial: "Thankyou for your help!"
Why the interior light of 1997 Acura rl stays on when then the door is closed.Even though the switch is set to door.
Do you have mirror above or near your front windshield? my lights stayed on a couple of times, and I had to get out my manual and see where to click them off. I think when I put my sun visor up it clicked it to the on position on the mirror. I don't have the same type car as you though, but that could be where your problem might be.
Apr 02, 2015 | 1997 Acura RL
Door ajar keeps flashing evan though the door is close
Good Afternoon Friend,
I understand the door ajar light keeps flashing even though the door is closed on your Frigidaire freezer, model# FFU17K1CW. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave the model number of your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 10, 2014 | Frigidaire 16.7 cu. ft. / 473 liter...
I just want to shut the f king thing You cant't use the keyboard properly if you just get close it's like double clicking Sorry I'm pissed Ican't even find it on the systems hardware...
press the reset button
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). Where the only thing that are working are the keyboard, mouse and files When the repairs are done, restart the computer, and allow it to boot normally.
May 24, 2011 | Computers & Internet
Even though driver door is closed,command screen says Driver Door Ajar.Interior lights stay on,except in drive.Even radio shuts off immediatly after shutting ignition off.Do I need to replace sensor??
Usually the solution to this problem is to use a good penetrating oil and spray HEAVILY the latch mechanism (both doors), let it soak in, and open/close the door 15-20 times-the sensor is in the door and it gets hung up, spraying lubricant on the latches frees it up.
May 01, 2011 | 1997 Lincoln Mark VIII
I have a 2007 Chev Equinox. The radio and instrument cluster will not shut off when the ignition is turned off and the driver's door is opened. It will shut off after about 5 min. later. Any ideas?
the problem may be in the drivers door switch.Even though the door is open the switch may be at falt.Even if the door were closed the radio will shut off after 5/10 mins.
Mar 21, 2011 | 2007 Chevrolet Equinox LS New Cars
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
Scion tc 2005: door indicator on gauge wont shut off?
check all of your door latches to see if they all work. If there are sensors on the body where the door closes toward the center B PILLAR of the car it has sensors for the doors, then push them in and see which one is bad. Sometimes the door sensors are located in the door actuator which usually goes to the driver;s door due to it's high use.
Jul 16, 2009 | 2006 Scion tC
Fluff escaping from my Creda Simplicity Dryer T522VW
You don't say how much fluff is escaping, but some things to check are -
1) That the lint screen is fully seated into the top of the dryer vent
2) All the way to where it discharges the house, is clean and free of restriction
3) Check that the dryer door gasket and lint screen cover gasket's are in good condition and do not allow air leakage.
Make certain the flex duct leading from the back of the dryer is connected tightly to the dryer and the vent duct, and make sure the flex duct is not split or broken.
Jan 22, 2009 | Dryers
Doors rattle
You could glue soft rubber blocks you have cut to suit and put in the appropriate places.Sounds like the door rubbers are a little worn.
Oct 13, 2008 | 1984 Ford F 150
Miele T8005 Tumble Dryer Logo
65 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
