Question about HP OfficeJet K7100 Photo inkJet Printer
Power on button is on and the print cartridge light is blinking...can the printer print
Can someone help why thhp officejet k7100 printer won't print..
  • HP Master
  • 9,771 Answers
Try replacing the ink cartridges.
Posted on Aug 11, 2016
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
SOURCE: hp officejet 5510 all in one cartridge error
There are several different ways I've come across which will resolve ink cartridge errors on the HP Officejet 5510.
HP's standard, pat answer to the problem is "Buy brand new genuine HP ink cartridges." If you refill your own ink cartridge or have it done at Walmart or somewhere else, you will eventually run into this problem. Why? Because the 5510 stores information on as many as 2 of the black ink & 2 of the color ink cartridges you have used in the machine - complete with an "expiration" date for each of those cartridges. You can refill them, but unless you clear the stored memory in the printer you probably won't be able to get around the errors. Even if you do, they usually come back in a short period of time. I know this because I own a 5510 & a 5110 and have battled this problem myself for a couple of years.
Short of buying "genuine new HP ink cartridges", using your printer for target practice, or testing it's aerodynamic design... lofting it not-so-gently from a 2nd-story (or higher) window... aiming for the nearest dumpster ;) you might try:
  • http://www.misterinkjet.com/hpreset.htm Scroll down and you will find links to pages for the #56 & #57 cartridge serial number reset procedure.
  • If the above doesn't resolve your problem, try removing both cartridges, then - with the printer still turned "ON", unplug the power supply cord from the back of the machine. After one minute has passed, press down and hold both the "#" button and the "6" button on the keypad and while pressing those buttons, reach back and plug the power cord back into the machine. The LED readout will indicate "Initializing" and "Reset..." Then, release the "#" and "6" buttons and wait until the machine re-initializes and prompts you to install ink cartridges. Reinstall the cartridges and see if the problem is resolved. The reset procedure, as well as other troubleshooting procedures (paper jams, ink cartridge jams, etc.) can be found here, on the HP support pages.
  • Another way of working around the cartridge error problem is to keep at least 3 sets of cartridges on hand, using the newest sets for re-filling. You may have to switch out 2 or 3 times just to get the machine's memory maxed out, but the third set should work. This particular method works best with OEM HP cartridges, but I've heard it works with other brands, too.
For more adventurous-techie-types, who can't resist tearing into the machine in an effort to resolve the cartridge error permanently, I found the following information posted on a DIY (Do It Yourself) repair forum:
The 5510 has a pair of 1.5v batteries which function much like the CMOS battery on the motherboard of your computer - they supply power to the memory chips which store the serial numbers and expiration dates of the last 2 sets of ink cartridges which were used. The batteries are sealed together at the top and bottom and are attached to a circut board inside the printer on the left-hand side. At a glance, they look a lot like a capacitor or something like that attached to the board. If you look closely, you will see the "+" and "-" markings.
Breaking the connection (located at the top) between these two batteries will clear the ink cartridge serial number info from the printer's memory - but be advised this will probably also clear other short-term memory items also - such as last number redial, etc.
The clever individual who posted this info actually attached wires - one to the top of each of the 1.5v batteries - and ran the wires out through the opening above the paper trays. The wire-ends are connected together - I imagine they would need to be held out of the way of the paper path with a piece of tape.
(M-I-C-K-E-Y...M-O-U-S-E) He, he
When it's time for a cartridge change/refill, the wires are disconnected to clear the memory, then reconnected again after the full cartridges have been installed.
I've read posts from people with different models of printers have mentioned installing a switch to clear the memory - a preferable solution than to have wires running out from the inside of your printer.
This is a widespread issue and regardless of how you resolve the error messages, one must always remember that when you bypass something that is built-into the design of an electronic device, you run the risk of damaging components. In this case, the biggest problem would be running too low or completely out of ink and burning out the print head on the ink cartridge; then you would end up having to replace the cartridge anyway.
Personally, I'm basically fed up with the way HP has been forcing people who buy their printers and All-In-Ones to pay outrageous prices for replacement cartridges, by building machines which generate error messages and reject refilled and non-OEM cartridges. Their drivers and software programs often have compatibility problems even with other HP products which are installed on the same computer with an HP printer. Too many problems for me - I won't be buying any more HP printers and I hear Dell is not much better.
While I haven't tried to jump out the memory on my 5510 yet, that will be my last and final effort before giving it the aerodynamics test... into the nearest dumpster!
Posted on Mar 17, 2008
SOURCE: Printer Won't Print
I had the same problem all you have to do is in the left side there is a black sorta arrow looking piece. You have to get this back in alignment... There is a white wheel right across from it push the the wheel down till you get it to the top where there will be a triangle like cut out.. You then need to push the point of the black arrow like piece to the left of the wheel so it below the wheels level... This is what is causing the smacking noise it is getting caught on this black arrow like piece.
Posted on Feb 16, 2009
celibytes
  • 70 Answers
SOURCE: Power button is blinking and Carriage is stalled
there are two cartridge one is the ink cartridge which can be found on the left side of the printer (in front)and the other one is the head cartridge that can be found on the right side if you will open the printer cover that is the carriage check it if the flip cover is lock properly then try to reinsert the head cartridge..
Posted on Sep 10, 2009
Testimonial: "I LOVE U MAN!! TNX FOR THE HELP! I HOPE I CAN BRING YOU PIE! OR SUMTIN' TNX SO MUCH ^_^"
  • 164 Answers
SOURCE: My ink cartridge light is blinking on my hp940c printer
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
Hp k7100 error blinking lights
color prin ter
ever like RTM
at HP.com?
i promise, magic happens.
here it is , at HP.com like 99% of whats used today:"modern"
http://support.hp.com/us-en/product/hp-officejet-k7100-color-printer-series/3440925/manuals
Jan 19, 2017 | HP Officejet K7100 Series
WHAT SHOULD I DO IF THE RED LIGHT IS STILL BLINKING I CANT PRINT IN HP OFFICEJET K7100
Here is a link to a description of blinking lights for your model HP printer at HP.com: http://bit.ly/1pMnPEu Hopefully this will help.
Aug 25, 2014 | HP Officejet K7100 Series
How to set print alignment in hp officejet K7100
During cartridge alignment, the error message 'Print cartridge alignment failed' displays on the printer control panel....
More Info visit this links...
Print cartridge alignment failed Error Message Displays on the All in...
Alignment Page Does Not Print
Thanks,
HP Printer Support
Jun 26, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
HP OFFICEJET K7100 NEW BLACK INK BLINKING
I watch a documentary recently called planned obsolescence and a russian hacker reported finding a chip in his printer that would count the number of print and then lock up once a certain number was reached. This printer was by no means cheap and I was expecting high quality product (something that would last) I think that this printer adopts these malware techniques. The joys of capitalism means companys have zero incentive to offer you products that last. So sick of scumbag corporations
Not to mention how many time I have had to align the printer heads (nearly every time I turn it on)
Jan 17, 2012 | HP OfficeJet K7100 Photo inkJet Printer
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
Sep 15, 2009 | HP OfficeJet K7100 Photo inkJet Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
HP OfficeJet K7100 Photo inkJet Printer Logo
Seeker5211
Seeker5211
