Picture up side down vertical retrace lines - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
Upside down picture is due to the connection reversal to vertical scan section winding at the deflection yoke.
If you wish to know more about retrace lines, and the repair work to it; visit this site. http://electronicshelponline.blogspot.com/
Reasons for retrace lines are given with illustrations.
Posted on Mar 30, 2015
4 Suggested Answers
SOURCE: av32d305 yaa retrace line on the top of the picture
yes on the top of the picture
Posted on Nov 29, 2007
  • 4234 Answers
SOURCE: RCA 24V511T Vertical problem
There is a problem with the vertical circuit. In many cases this is either poor solder connections or a defecitve vertical IC. If you can solder you should be able to fix this yourself. Please note that there are potentially dangerous high voltages present inside the set even when unplugged. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Thanks,
Dan
Posted on Jan 30, 2009
  • 26 Answers
SOURCE: JVC Television Model AV 27820
One or more of the electrolytic condensers near the vertical ic are bad
Posted on Nov 20, 2007
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
Why do i have white lines on my 26
Hello
The fault is with the vertical output section of the TV. The lines you see at the top side, is technically called 'vertical retrace' lines. The main cause to this fulat is with electgrolytic capcitors at the vertical output section. Repalce all the electrolytic capacitors at this section. There will be 5 or 6 numbers of them. Repalce all at the same time. This must solve the problem to your TV.
Mar 19, 2012 | iLO Televison & Video
How do you repair or rather remove the retrace line on screen there is no picture
You have may the brighteness set up too high. if not retrace blanking is faulty. try turning the brighness down a bit.
Dec 19, 2009 | Daewoo DTQ-13P2FC 13" TV
Lines at top of screen
I have seen issues with complaints of raster with vertical retrace lines at the top of the picture and capacitor 2494 needs to be removed.
Jul 23, 2008 | Philips 27MT3305 27" TV
Nov 20, 2007 | JVC AV-27820 27" TV
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
