I have a go ped and when i start it up it runs smooth but then it sputers out about 5 sec after its been runing
Sounds like a fuel issue. Just enough gas getting there to start it, but not enough to keep it running. Start at thefuel line to the carburetor. Make sure fuel will come out at a sufficient stream. If it doesn't, work backwards towards the fuel tank, looking for clogged fuel lines and such. Clean whatever is suspect. If you get fuel all the way to the carburetor, you'll need to clean the carburetor. Careful disassembly is critical to getting it put back together correctly. Clean your parts with brake cleaner, not carburetor/choke cleaner, paying particular attention to orifices.
Best Regards, --WoobieDog--
