Question about Bosch Dryers
My bosch maxx 8 sensitive dryer of late had to be restarted because the clothes were not fully dried. Yesterday it just stopped. What do you suggest I do?
  • robert Mar 30, 2015
    Hi alan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? check to make sure you have no blockage in your vent and that you have a strong flow
  • Bosch Master
  • 5,323 Answers
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Posted on Apr 26, 2015
SOURCE: bosch maxx wtl 6300 dryer when
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
Posted on Oct 25, 2008
guru_dev
  • 315 Answers
SOURCE: no heat in dryer.
First, I assume that the drum spins OK but there is no heat. Many things can cause this. From the most likely cause to the least likely:
1) An open thermal fuse. This is a small "thermostat" with 2 wires at the middle/top of the heater "box" (a tall narrow box on right in the back of the machine), or a plastic type on the duct close to the blower, depending on the model. You will need to remove the back cover of the machine to see these. Check with an ohm meter after disconnecting one of the leads, or jumper the 2 wires together to see if heater works (don't use this way though, fire hazard... replace the device) If this proves to be the cause of the problem, it would be wise to check all ducts and blower for excessive lint buildup. This will reduce air flow, causing overheating and blown thermal fuses.
2) A burned out heating element. Remove tall box on right, element slides out from the bottom together with the "carrier". Look for broken coil, or check 2 terminals at bottom with ohm meter.
3) Burned wires at connectors. Check for obviously overheated wire terminals at all sensors (thermostats and thermal fuses in back), heater box, main terminals where power cord hooks up, etc.
4) Bad thermostats. There are usually 2 or more. A high limit on heater box, just above terminals on the bottom. 1 or 2 will be on the duct next to the blower. Check these with an ohm meter (or continuity checker). Some have 4 terminals, the extra 2 small terminals are small heaters inside the thermostats which alter it's temperature characteristics. These will usually read around 4000 ohms or so. Check the 2 main largest terminals for continuity.
5) Only getting 110 volts: This is often overlooked, but if for some reason one of the poles feeding the 220 power from the house wiring is open but the other is OK (for example, houses with fuses where only one fuse is blown, or a bad circuit breaker with one pole open). The motor and timer run on 110. If the side of the 220 line that feeds the motor is OK but the other one is open the motor will run but the heater, which needs 220 will not heat. Check for 220 volts between the 2 outer terminals where power cord connects or between the 2 "hot" terminals of the 220 outlet the dryer is plugged into.
6) Bad centrifugal switch in motor. This is what actually turns the heater on, for safety reasons, so the heater cannot come on unless the fan is spinning. Otherwise without air flow past it, the heater would burn out.
There are 2 large gauge (usually red or yellow) wires going to the connector on the motor, these go to the contacts inside the motor that turn the heater on.
Posted on Jul 20, 2009
SOURCE: Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Posted on Apr 01, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Hi There, My Roper dryer stopped drying clothes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
TheMobilian
  • 8220 Answers
SOURCE: My new Bosch maxx 6
It could be something as simple as the water drawer is not properly in it's little compartment. Try repositioning it. This video shows how a dryer like yours works:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 01, 2010
I have a Bosch Maxx 8 sensitive drier and it sometimes will not start but if it does it will stop and reset the clock and sit there waiting like its at the beginning like you haven't done anything!
any service tech will tell you get a basic one without all the options, you'll be happier, even the manufacturers dont know how to fix these yet
Feb 01, 2015 | Bosch Dryers
I have a Bosch Maxx Sensitive WTE84100AU dryer which stops a few minutes after the dryer starts. The dryness lights all turn off. The clothes don't dry.
There is a thermal overload switch behind the back cover. It has overloaded because the big lumps of lint in a) lint basket, b) small vents either side of the vent basket (use a chopstick), c) in the big pull out condenser unit at the front bottom left, and d) reach right to the slot for the condenser unit and scrape all the lint out of the back.
Now you can do the reset - unplug your dryer first. You will need a Torx T15 screwdriver to undo the all screws around the fan & drum cover, then use a thin blade to pop off the back cover. If you don't have a Torx screwdriver, you will have to buy or borrow one - there are just too many screws to use anything else.
I was thinking of drilling a 6mm hole in about the right spot so I can poke a chopstick through to press the reset button. 6607f76a-b20b-43ef-8059-a4858d51d2dd.jpg
Jan 08, 2013 | Bosch Dryers
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Tumble stops cycle when drying. its starts to dry but stops after a short while leaving the clothes still wet,after restarting several times the cothes dry
use multi meter and check moister sensor, cycling and hi limit thermostat lastly if it runs about 25 minutes then stops and need about an hour b4 it will start agin? u have bad motor windings
Nov 08, 2011 | Bosch Axxis WTL 5400 Dryer
Bosch maxx 7 sensitive dryer wich stops everytime and shows that there is a problem with the reservoir
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Dec 18, 2010 | Bosch Dryers
Clothes dryer stops spinning before clothes are dry
sounds like a bad cycling thermostat!
May 26, 2009 | Bosch Dryers
Dryers Logo
198 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
