Question about Dryers
The electrical works but the heating is not working
    Scholar:
  • 90 Answers
If you have absolutely no heat in the unit at all, it is likely the thermostat described in the above description, or the element itself. Both are easy to replace, cheap compared to a repirman, and can be done at the same time. Here is a video I used to replace the heating element on my dryer. I have hard water in my state and it has gone out twice in 5 years. Dryers are all very similar. A big drum with a motor to turn it and a blower that sends the air past the heating element and through the drum, then through the lint trap and out the vent. You may have to access it differently (Back vs. front panel) but they are all very similar. in addition you can normally find the part itself at a local repair shop and put it in yourself. Hope this helps, and don't forget to rate!!
Posted on Mar 30, 2015
  • Dryers Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
The oven does not heat up. the microwave work and everything in terms of the display on the oven works, but no heat.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ][
May 08, 2011 | GE JTP86 Electric Double Oven
The oven heating element isn't working, but the broiler is working. The stovetop works fine.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 19, 2011 | Kenmore 95032 / 95034 Electric Kitchen...
Electric Dryer works, but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 12, 2011 | Frigidaire Electric Dryer
The oven will not work, power is on, stove top works, light works, display is off, no heat. The control lock and delay feature is not set
heatman101
Jan 10, 2011 | Whirlpool GBS309PVS Stainless Steel...
Oven not working bottom element not working top on broil works ok
heatman101
Sep 05, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
MY BOSCH ELECTRIC RANGE NOTHING WORKS, GET POWER NO HEAT
u may need to set ur clock to manual operation. check instructions if u hav them
Feb 06, 2009 | Bosch HEI7132 Titanium Electric Range
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Dryers Logo
54 people viewed this question
Top Dryers Experts
