Question about Frost Refrigerators
FROST OR ICE IS FORMING IN THE FREEZER - Frost Refrigerators
  • Frost Master
  • 5,323 Answers
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM
Posted on Apr 07, 2015
aborcass
  • 2651 Answers
SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 20, 2008
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
  • 16 Answers
SOURCE: freezer frosts up and stops cooling after approximately 2 weeks
either low in freon or defrost timer stuck or unit needs cleaning, remove front louver panel on bottom (either 2 screws or snap fit) look for timer then use small straight screwdriver to turn slowly till clicks then wait to see if working properly, if not could be problem. if you see a lot of dust bunnies while doing then clean with vacuum and do same to back area also
Posted on Jun 02, 2009
tborn6
  • 700 Answers
SOURCE: Freezer-Ice forms on food in the freezer and ice
check the door gasket to see if theres any tears or if its dirty, also check the coil on the back to see if theres any dirt on it if so it needs to be cleaned.
Posted on Jul 02, 2009
SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Posted on Oct 22, 2009
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
The frost free freezer has started to form ice
First point of investigation, is to check the door seal. Sometimes new seals get stuck-suction and when opened and shut possibly cause a small tear, lubricate very gently with Vaseline, this will enable the seal to firstly seal properly and secondly not put undue pressure due to suction on new door seals.
If that does not resolve it then have a technician check the thermostat.
Mar 04, 2015 | Frost Refrigerators
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Why is my ge refriderator "frost-free" freezer frosting up?
most likely the defrost heater behind the panel thats frosted up is burned out so it cant defrost the unit,g.e. is notorious for this,remove this panel inside the freezer and remove 2 screws at the bottom of the evaporator coil holding the heater to the evaporator and unplug it the new part number is g.e. WR51X10055
Jul 23, 2012 | GE GSH25JFT
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice melting and frost forming on freezer side, funny sound coming from freezer side. No condensation in back of fridge. Help for a new home owner.
check that your flapper on the ice shut through the freezer door is fully closed,
make sure there is no ice forming around your evaporator fan, thats the fan in the freezer, if that gets glogged with ice and is forced to stop, it could blow your entire machine control......
the frost in the freezer leads me to believe you may have a defrost issue
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Jun 28, 2009 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
Frost forming around ice dispenser inside side by side Fridge
The presence of frost indicates that the dispenser(ice) probrably isn't closing all the way once you get ice. This allows warm air to rise up, condense and form frost. In all likelihood the solenoid that controls the opening and closing is bad and needs to be replaced.
Jul 10, 2008 | Kenmore 55692 / 55694 Side by Side...
Refrigerators Logo
43 people viewed this question
Top Frost Refrigerators Experts
Charles T Nevin
Charles T Nevin
Mike
old fart58
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
