Question about Balance CM2019 19" LCD Monitor
WHAT IS THE PIN CONFIGURATION WHERE SUPPLY CORD PLUGS INTO REAR PANEL OF MONITOR?
WHICH PIN(S) IS POSITIVE, WHICH IS NEGETIVE?
    Master:
  • Balance Master
  • 496 Answers
There is no wrong way to plug in the cables into the monitor.
If you're referring to the male/female cable ends... you will always need a male to male cable from a monitor to a device.
WHAT IS THE PIN CONFIGURATION WHERE SUPPLY CORD PL - 25616839-cbt13vi4zbmnff1d5zdl02jb-2-0.jpg Or DVI:
25616839-cbt13vi4zbmnff1d5zdl02jb-2-1.jpg Need any more help? Reply!!
Posted on Mar 30, 2015
Dewalt Corded Drill won't turn on
TRY THIS TAKE THE DRILL REMOVE ALL SCREWS OPEN IT
FIND THE POSITIVE AND NEGETIVE ON THE MOTOR HAVE A 12 VOLT BATTERY AND 2 CABLES 1 RED 1 BLACK 6 F-LONG 1-CONECT THE POSITIVE CABLE TO POSITIVE ON BATTERY AND NEGETIVE TO NEGETIVE ON BATTERY NOW YOU CHECK THE MOTOR ON DRILL BY TAKING POSITIVE AND CONNECT TO POSITIVE ON DRILL AND NEGETIVE TO NEGETIVE ON DRILL IF THE MOTOR RUNS THE PROBLEM SHOULD BE SWITCH.YOU CAN BYPASS THE SWITCH SOLDER THE WIRES TO THE MOTOR AND USE IT IN THE MEANTIME. SCREW THE CASING BACK TOGRTHER
YOUR DONE VERY SIMPLE..
GOOD LUCK.
Feb 04, 2018 | Dewalt Air Tools & Compressors
I need an internal pin out diagram for a 4 Pin connector to connect power supply to a hp pavillion f70 monitor. I do have a power supply with same specs but it has a normal plug with outer as +ve and Inner...
12 VDC , 4.16 A (4,16 A) Frequency: 50/60 Hz Power Consumption: less than 36 W in operating mode.
I think the other two pins are not used. It just requires the 12 Volts DC. +ve and -ve, positive and negative, respectively.
Feb 10, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
How many cords attach to back of monitor?
two cords
one for power supply
another for data with multi pins in it
Aug 21, 2010 | Princeton Digital LCD1510 15" Flat Panel...
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
How do i connect 4ohm speakers to my 8ohm jvc receiver
You must connect two sets of speakers to do this.
You must connect them in series.
Meaning, you connect the positive of one to the positive (red) on that reciever. Then you connect the negetive of that speaker to the positive of another four ohm speaker, then run the negetive of that speaker to the negetive on the reciever. Just like if you were connecting batteries together.
Remember never to connect multiple speakers in paralell. (positive to positive and negetive to negetive) as this would make four ohm speakers into a two ohm configuration.
You can use speakers with higher ohm ratings in this setup. For instance, if you connect an eight ohm speaker in series with a four ohm this would give you 12 ohms. Which is also acceptable.
Feb 06, 2010 | JVC Audio Players & Recorders
I need power cords for my monitor
The monitor needs a power cord and a signal cable. The power cord is a standard 3-prong detachable cord just like the one on nearly every desktop computer and many other electronic appliances.
The signal cable may be one of two types, depending on your computer's video connector. The monitor has connectors for both VGA (a D-shaped connector with 15 pins) and DVI (a rectangular connector) inputs. You need a cable with whichever type of connector fits your computer.
You should be able to find the power cord at Radio Shack, any of the big office supply places, or retailers who sell computers. The signal cable may be available there as well, or you can order from a number of online vendors.
The monitor also allows you to plug in a USB cable from your computer so you can plug in USB devices like a keyboard or mouse. For that you need the same kind of USB cable you would use to connect a printer.
You can view or download a copy of the monitor user's guide at Dell's site here:
http://support.dell.com/support/edocs/monitors/1704fpt/EN/index.htm
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Feb 21, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I need a power supply for my Kogi L7EH-TA monitor
I would not recommend this because my monitor will probably burn up from doing this but; I just lost my power supply last night and I took a power cord from my seagate external 500 GB hard drive which has the same pin size plug in that goes into the monitor and plugged it directly into the wall. I assume that the external hard drive uses the same ac to dc converter although it looks just like a cord with no inverter capabilies. Not sure of the amps though and this could burn up the monitor completely. Works for now.
Mar 04, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
MAG INNOVISION
The socket for the AC power supply is located RIGHT ON the cord that plugs into your tower/graphics card. I just bought one today at the thrift store, ** power cord, but was looking for the input myself and found it there. Hope that helps.
Feb 18, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Jumpers problem
170dd8e.jpg This is a jpg of a modern board. Your board may have more pins. The concept is close. Any difference would be located at the Power led. Your's could be three pins & the speaker could be three pins & neither connector would use the middle hole. I suggest you plug in one connector at a time with a boot up in between. Start with the power switch. Testing is simple, press the case power on button. Pc starts your good no light? Turn the connector around & try again. Next plug in the IDE led. Check for light on power up. Most boards, old & new keep their negetive facing to your right. These negetive wires are colored black & wihte. Positive wires are colored green, blue & red. As long as you do 1 connector at a time you should not have a problem. These are all very low voltage, most just leds. Take your time. It will work out.
Jan 14, 2008 | Matsonic MS8127C (MBMS8127C) Motherboard
Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Jan 06, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
Balance CM2019 19" LCD Monitor Logo
62 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
