Question about Epson Stylus CX3200 All-In-One InkJet Printer
POOR COPY QUALITY
HOW DO YOU CLEAN UNDER GLASS? CAN'T SEEM TO GET APART.
    Problem Solver:
  • 10 Answers
UNPLUG THE PRINTER.
lift scanner lid from the back, it slides up,
underneath there are two screws , one on either side. remove them.
under the control panel there is a gap, this pulls up to reveal the inside of the printer.
on the scanner flap, there are two screws, one on either side, remove them.
Make sure the lock switch is in the open position. or remove it with a screwdriver. it pops off.
now. the lid unclicks at the back and slides forward to remove.
there is a wire connector strip that goes to the control panel. if it comes off simply push it back in carefully, making sure it has been pushed in firmly.
reverse to put it back together.
Hope this helps.
Posted on Nov 26, 2007
Keyocera km 2560 poor quality copy but good quality report print
dear clean the platen glass and its cover. adjust the sharpness.darkness.image quality to text and photo.
your printer is in good condition.
thanks.
Mar 30, 2015 | Office Equipment & Supplies
Quality of copies very poor, how do I clean them up
open the buttons cover and underneath there is a rectangle glass surface. clean it and your copies will be ok, considering that the printouts are ok. If both are poor, then the problem is the consumable. If after that still only the copies are poor then its a Scanner problem or motherboard
Feb 19, 2015 | Brother PPF-5750E 33.6K bps Super G3 Fax...
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
Hp laserjet 4345 when scanning from adf copies too light
Take copy with default settings, if quality is poor, need to clean inner parts like reflecting glass, engine reflector of optical scanner assm(CCD)..& flat bed glasses both sides.
Note: with out proper knowledge pl don't open this printer..
Sep 30, 2011 | HP LaserJet 4345mfp Printer
Why is there a line on the left side of my copy when I use the ADF on my Canon Image Clas D1150? It does not do it when the flatbed is used. Please help. Thanks, Joann
When lines appear on copies of documents fed through the ADF, it typically means that there is some kind of dirt or foreign material on the glass that the document passes over. A different window is used when scanning from the ADF as opposed to the flatbed. The flatbed window is large, often much larger than a standard sheet of paper. The ADF window, on the other hand, is small and slender. It doesn't need to be large because the document moves over it (as opposed to the flatbed, where the document is stationary while the scanner moves under it).
The ADF window is usually situated next to the flatbed glass on the side of the scanner where the ADF takes in the paper. Open the scanner lid (as though you were going to make a copy on the flatbed) and find the slender piece of glass just under where the ADF would be when the lid is closed. Once you've located the ADF glass, use a mild glass cleaner and a lint-free cloth to gently clean the surface of the glass. If you are able to see the foreign material, you can remove it by hand, but be sure to clean the glass thoroughly afterwards, as fingerprints can also cause poor quality copies.
After the glass has been cleaned, test the ADF copy function and make sure the line has disappeared. If it has not, you may need to remove the slender glass and clean the underside (though this is almost never required, as the underside is protected from environmental debris).
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Canon imageCLASS D1150 All-In-One Laser...
Gestetner DSC 232SP: I purchased this copier used and it had printing ok. My color copies are coming out horrible. they are displaying a white line in the same area on page after page. Even after I ran a...
The white line or lines are NOT caused by the fuser. A defect "line" in the fuser would cause the symtom of the print rubbing off the page but not blank lines on your copy. First we need to separate your copy quality issues. This machine uses 4 drums, 4 developer units and a transfer belt. Most copy quality issues will reside in 1 or more of these units. Lets start with a few questions. 1)Are your copy quality issues ONLY on color copies? or are the black and whites poor too? 2) Are you running copies only thru the document feeder or have you made any copies from the glass?
Are you printing on the copier from your computer?
Dec 04, 2009 | Gestetner DSc232sp Copier
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
RE: SENDING FAX
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Poor image quality
Sounds like you need to disassemble the scanner and clean it thoroughly, If that seal glass area is hazed up it will cause that problem.
May 23, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Poor print quality
remove the drum unit from the machine, you will see a glass called **** glass under the drum unit. if that glass is dirty, just clean it with alcohol and cotton.
white lines is the cause if that part is dirty.
call us at 02 3633636
Pantronics International Corp.
manila, Philippines
May 11, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
Epson Stylus CX3200 All-In-One InkJet Printer Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
