Question about Crate Music
How do I fix my crate b80xl
Cuts out while playing
    Top Expert:
  • Crate Master
  • 3,107 Answers
Without hearing it in action, it's hard to pinpoint a problem. It could be as simple as a dirty jack, or it could be components overheating, or something else entirly. I'd take it to the repair shop.
Posted on Mar 30, 2015
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Crate bv120h weakness.
bad wires or fuse or connections
Jan 05, 2013 | Music
I have a Crate v32 1X12 guitar amp, the volume cuts out and then begins to feed back. To make a very long story short the tubes are good (I KNOW the tubes are good!!!) it is not the cords pedals etc. any...
I don't know how you know the tubes are good... It is possible they are microphonic... try tapping them with a pencil (only need to worry about the smaller ones).
Beyond this look for cracked circuit board or bad solder... especially near the control pot leads. This is a common problem. Look for cracks near the booard mounting points.
Dec 23, 2010 | Crate Cfs3
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud...
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Sep 15, 2010 | Crate Music
I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
Mar 26, 2010 | Fender '72 Tele Deluxe Electric Guitar
Crate flexwave 120 head sound cuts out
You have a broken solder joint. You'll have to disassemble the amp enough to get at the soldered side of the circuit board that the controls are mounted to and touch up any suspect solder joints. Just be sure to resolder only the joints that were originally soldered or need to be soldered. Hope this helps.
Jun 07, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Loss of power while playing
If you can solder, try resoldering any connections on the board that appear grainy or have rings. It is likely that after the unit has been working for a while, the heat is causing a marginal connection to open up.
Keep us posted.
Dan
Feb 16, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
Top Crate Music Experts
rjivaro
Michial Gueffroy
Ben Armstrong
Are you a Crate Music Expert? Answer questions, earn points and help others
