Question about ION Block Rocker
When playing radio volume is weak as if only coming out of a tweeter
It's an older block rocker, not a bluetooth
The tweeter stopped working on my Ion Block Rocker, any suggestions? Tore apart, all wires are still connected.
Take the tweeter out, and tap wires to a AA battery to the connectors. If no clicking sound from tweeter, it's fried, and you need to replace it.
Jun 13, 2016 | ION Block Rocker
I have an ion ipa56c block Rocker. The battery is brand new. It gets a full charge and only last a few hours . Help
Block Rockerâ„¢ Bluetooth iPA56C - ION Audio
www.ionaudio.com/products/details/block-rocker-bluetooth-ipa56c
Block Rocker Bluetooth iPA56C provides up to 75 hours of on-the-go sound with its long-lasting ... A high-quality microphone is included to get you started.
RE: Block Rocker Bluetooth model differences - Ion Audio ...
community.ionaudio.com/ion.../block_rocker_bluetooth_model_differe...
Jul 6, 2014 - IPA23 - Explorer Bluetooth, Block Rocker Bluetooth, Block Rocker ...Besides the addition of another bluetooth port and the 75 hour battery on ... Bluetooth models IPA56B or IPA56C..... and between the last 2 what the differences are ? ... I have a model that says it's a iPA56B but only has a 50 hr. battery life.
Amazon.com: Ion Audio iPA56D Block Rocker Portable ...
www.amazon.com > ... > Karaoke Equipment > Players
Amazon.com, Inc.Amazon.com: Ion Audio iPA56D Block Rocker Portable Bluetooth Speaker System ... I work at gm and have bought 4 bluetooth speakers before this one for work use, ....block rocker battery power lasts only a few hours and blue tooth stopped ...
Amazon.com: ION Block Rocker Bluetooth Portable Speaker ...
Amazon.com, Inc.Ion Audio iPA76A Block Rocker Portable Bluetooth Speaker System with ..... I work at gm and have bought 4 bluetooth speakers before this one for work use, All of .... block rocker battery power lasts only a few hours and blue tooth stopped ...
ION Audio Block Rocker, Job Rocker, and Tailgater - Battery ...
noterepeat.com > ION > Portable Audio
Feb 08, 2016 | Tablets & eReaders
The radio in my 1995 jeep grand cherokee plays full volume on the right channel when turned on.
  1. bad radio amp
  2. bad wiring to speakers.
  3. or bad speakers.
the tests are easy, ask.
my guess is the weak side is bad, the load side is ok.
you can turn the volume down on the load side using volumn control
if yes that side is ok, fix weak side.
ask how, but make sure the wiring in all 4 corners are not damage
and at both ends of harness.
Feb 27, 2015 | 1995 Jeep Grand Cherokee
2007 camry radio
hey, that sounds like wiring for sure, if your cd player is working fine and its just your speakers? then yes that would be a wiring problem, theres a bad wire somewhere in the system. either find out yourself where the bad wire is or bring it to someone who know how to repair those types of problems. good luck!
Feb 15, 2014 | Cars & Trucks
I have wharfdale atlantic 400se. The tweeter is no longer working. How do i work out if it is a cross over or the tweeter
If there was a traumatic high-volume event that preceded this problem, I'd guess the tweeter died.
If you can access the connections on the tweeter and you have an ohmmeter, you could disconnect the tweeter and measure across the the terminals. A shorted or open voice coil = dead tweeter. A measurement near the stated impedance is probably ok.
If you have NO ohmmeter, you could carefully connect the output of one amplifier channel directly to the tweeter and just scooch the volume upward slightly from silence while playing something with very little bass in it. If you hear it, the tweeter is alive.
Apr 18, 2011 | Wharfedale Atlantic 100 Rear Speaker
Tar like adhesive has gone sticky round speaker cones and volume has droped
The tar like sticky substance is the suspension of the speaker cone and there is nothing wrong with that. Its doping compound applied by the speaker company to damp the speaker ( Was it not always there? ) If the suspension has come off the bass notes will flutter, if not its some other problem. Play some music and put your ears near the tweeters flared horn to see if they working. Nearly 30% of your sound comes from the upper part and if you have damaged it there will be a volume drop.
These speakers are quite complicated on the inside. It has two amplifiers, one for the woofer and one for the tweeter. It also has a digital sound processor. Any thing could be at fault, even a simple wrong setting.
Mar 09, 2011 | Behringer Eurolive B212A Speaker
Tweeter plays and very low volume when in back by
This sounds like I would be trying a new crossover network module.
Jerry G.
Aug 06, 2009 | Infinity IL 10 Main / Stereo Speaker
ISymphony CRDCD clock radio alarm programming
Play around with the Alarm1 button, test it every minute and when it goes off press Alarm1 again to stop it, not snooze. Then try pressing vol + as nothing is playing. Keep trying until your alarm goes off at the desired volume that you put in your Alarm1 settings
Mar 07, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
ION Block Rocker Logo
74 people viewed this question
Top ION Audio Players & Recorders Experts
Jay Plesset
Jerry Kramer
Jerry Kramer
richie46
Are you an ION Audio Player and Recorder Expert? Answer questions, earn points and help others
