Question about GE Dryers
GE DBVH510EH0WW Electric Dryer. Display buttons will not light. Dry time timer is the only thing that lights up. Dryer functions normally. Just can not determine which setting you are on nor the dr
GE DBVH510EH0WW Electric Dryer. Display buttons will not light. Dry time timer is the only thing that lights up. Dryer functions normally. Just can not determine which setting you are on nor the dry temp setting due to these no longer ilumimating when unit is turned on.
  • GE Master
  • 15,729 Answers
This could be the control panel. They are easy to replace
Posted on May 13, 2015
  • 833 Answers
SOURCE: Maytag atlantis electric dryer
Sounds like the moisture sensor has gone away. Not sure where it is located on this model, though.
Posted on Dec 21, 2007
  • 18 Answers
SOURCE: LG DLE0332W Electric Dryer- The
Had the same problem, dryer got hot but didn't stay hot. sounds like you have a bad sensor and it sounds like it's out of warranty.
Posted on Jun 08, 2008
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
MNTECH
  • 1543 Answers
SOURCE: Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Posted on Nov 13, 2008
  • 163 Answers
SOURCE: Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Posted on Mar 06, 2009
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
The optimum dry is not working - dbl333eb
they have a sensor it will have a few metal strips inside the dryer. ge usually right by the lint filter. it most likely that or whatever feeds it. the auto dry sensing board or timer. sensor, sensor board or timer. most of time sensor is bad.
Aug 01, 2010 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
My Frigidaire AEQ6700FS electric dryer starts normally but only runs for about 30 seconds, then stops. The lights and display stay on, and the 3 lights at the far right blink all at once. There is no error...
try the timed dry setting there may be a problem with the moisture sensor bar.
you should also check the thermal fuses inside the dryer.there maybe one that is weak or bad
Mar 14, 2010 | Frigidaire AEQ6700FS Dryer
Dryer switch grinds and sometimes starts, most times not
Sounds like the overload switch is cutting out , my gues will be that the motor is going bad. Just replaced mine was doing the same thing.
Jan 20, 2009 | GE DBL333EA Electric Dryer
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Problem with my GE dryer
  • turn your circuit breaker off then back on. sometimes the only one side of the dual 220v breaker will trip leaving you with a non functioning machine thats seems to have electricity going to it.
  • another thing to check is the door switch.
Jul 06, 2008 | GE DCSR483EA Electric Dryer
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Won't start. The start light flashes. Timer appears to be functioning.
You could have a couple of things going on that may cause your symptoms. First of all, unplug the dryer. If you can access the inside of the dryer check to see if the dryer belt is broken. On some dryer models if the dryer belt breaks a "broken belt relay" on the idler pulley near the motor will trip causing the motor to shut down. This is to prevent a broken belt from becoming wrapped around the motor shaft. Another possibility is a blown thermal fuse or thermal cut-out. Some dryer models have a thermal fuse mounted on the exhaust vent housing and is white in color. This should read a short. There should be a thermal cut-out mounted on the heating element housing as well. There will be a hi-limit thermostat mounted near it. The thermostat will have a resistance reading (can't remember exactly what it is), and the thermal cut-out should read a short. If the thermal c/o is bad, replace the hi-limit thermostat as well. Now if you have a thermal fuse or thermal cut-out problem, they generally blow for a reason. Check your dryer ducting for proper air flow and make sure its not clogged full of lint. Normally, a thermal problem is associated with your dryer overheating. Good luck and let me know if this helps.
Jun 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
there is a possiblity that the door switch is not working. if you are handy refer to he parts book to see how to remove the switch and check for continuity.
Dryers Logo
79 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
