Question about Car Audio & Video
When I stay my car, my subs rumble for about 5 seconds. I've check my power, ground and remote. Please help! Is my amp done?
  • 113 Answers
SOURCE: Amp will not turn off and the Remote wire is correct.
check pwm chip ,may need replacing
Posted on Aug 22, 2007
  • 631 Answers
SOURCE: my amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Posted on Nov 30, 2008
SOURCE: amplifier does not turn on when head unit is turned on
Wow guess you dont need help sound like you need a new amp! ohhhhhh wait I changed my name and NOW DO YOU SEE HOW HARD IT IS TO GET A NEW NAME YOU HALF WITT WANNA BE ******???????/ ENJOY AND GOOD LUCK BECAUSE I TALK TO OTHER PEOPLE WITH THIS NEW NAME TO.......HOW MANY NAMES DO YOU WANT ME TO COME UP WITH. i CAN COME UP WITH ONE EVERY THIRTY MINUTES.........HOW MANY TIME YOU GONNA POST A NEW QUESTION............. OHHHHH AND DONT FORGET THE ABUSE BUTTON ON THIS ONT TOOOOO BECAUSE MY NAME ISNT ON THIS ACCOUNT EITHER JUST ANOTHER FREEEEEEE E-MAIL ACCOUNT SOOOOOOOOOOO HAVE FUN AND CRY YA HEART OUT........UNLESS IT IS THE FBI YOU CANT TOUCH THIS AS OLD SCHOOL MC HAMMER SAID.
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: 3 amps 2 subs sound system for car, need wiring help
it is easy to hook it up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jan 14, 2009
  • 133 Answers
SOURCE: Alpine mrp-m450 Amp won't stay on
Sounds to me like it might be the remote turn on because the first time i installed it, it did the same thing, and i found out that there is two blue wires coming out the stereo, one with a white stripe, i connected it to the blue wire, and it didnt work, then i connected it to the blue and white wire, and it worked. Well hope this solves your problem, goodluck.
Posted on Jul 06, 2009
I have a jl 500/1 amp hooked up in my car and the power light comes on for about 5 seconds then turns off. no sound out of the subs. it is hooked up to a factory deck through a high to low level converter....
hook up the remote wire ( or make sure its hooked up good) check your ground! ground wire not big enough awg wire and put on bare metal not more than 1 foot away from amp. bad ground will cause this.
Sep 12, 2011 | Jl Audio 500/1 Car Audio Amplifier
Sound turns on and off. Green light sound, red light no sound. It is like playing name that tune. A few seconds of music then off then on and repeat. It is not the deck as it has meters showing output. The...
Amp is probably going into protection mode, or does not have enough current from the power wire to continue operating. Check that the speaker wires are not shorting out against each other. Also check your power wire and ground wire. Ensure that the amp is solidly grounded. Are you using the proper gauge of power and ground wire? (4awg recommended.)
Mar 10, 2011 | Coustic Car Audio 481QE Car Audio...
I have a power acoustik bamf 1600/4. not working 5 hours later
use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
Dec 29, 2009 | Power Acoustik BAMF1600/4 Car Amp
I just moved my 12" kenwoods to a new car. i'm running a 760watt amp with 6 guage wire. last week they sounded crystal clear, no rattle or anything. but this week they have a constant loud rumble,...
It sounds like you have a feedback problem between your amp and your speakers this is usually caused by a bad or weak ground between the amp and chassis ground and speakers and chassis groung, also make sure that the correct post on the speakers is the one attached to ground as this makes a big differance especially with high power systems. Hope This Helps Don
Dec 02, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Blowing fuses on the Vosonik VB101PK
ok, always use ground and positive from speakers to the amps +/- . Make sure the amp is not grounded. Some amps are made of metal and will ground itself. When ever any fuses pop, this means that something somewhere got grounded. If using metal srews to mount amp that has a metal casing, chances are you will pop a fuse or two. Be careful ajusting the speaker wires with a metal srewdriver, I've done that alot. "POP"
Jun 21, 2009 | Visonik V117SX Car Audio Amplifier
INFINITY AMP PROTECTION LIGHT FLASHING
Overload maybe. If the amp is run at an improper impedence, the amp will shut down. If you are "CLIPPING" speakers / subwoofers the light will blink to indicate a hard clip . Example: 4ohm/2ohm stable amp with 4 ohm subs wired at 1 ohm.
Jan 28, 2009 | Infinity Reference 7541a Car Audio...
Emits a loud hum or rumble sound.
This problem is usually because of grounding.
If you look at the power lead, you will notice it is the regular "kettle plug" shape, but it only has two pins (live and neutral). There is no earth connector.
You have to ground the sub to your receiver. This is done by running a RCA connector connected to one of the unused connections to the amp.
However, this doesnt ALWAYS solve your problem. As in my case. I have a Pioneer 7.1 receiver, which is ALSO not grounded. so running a spare RCA cable has no effect. What I have done is wired a RCA connecter to a copper cable and connected the other end to the Earth pin on a 3 prong plug. This is plugged in to a wall socket, thus grounding the sub.
It's not a solution the manufacturer will suggest, but it seems to work for me.
Nov 12, 2008 | Boston Acoustics XB6 Speaker
Power
Have you checked the on-board fuses?
Did you confirm (with a multimeter) that you have voltage on the B+ and remote terminals of the amplifier?
Did you have the black meter lead on the ground terminal of the amp when you checked the voltage?
Jul 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
