Question about Blu Studio 5.0 S D570I Unlocked Dual Sim Phone with Quad-Core 1.2GHz Processor, Android 4.1 JB, 5.0-inch IPS High Resolution Display, and 8MP Camera Black
Im having trouble with internet, how do i get it back?
I reset factory settings so i could send and recieve pictures and now i have no internet
Why cant i recieve or access the net and picture sending on my sgh600
check your internet settings and for sending pictures you need to do another seeparate settings for mms.ok.which operator do you use.tell me,i will send you the settings
Mar 31, 2012 | Samsung Cell Phones
Web and Picture messaging not working.
You need new setting for the picture messaging service.
Most operators use different setting for PAYG and Contray customers because of they billing (PAYG needs to use a different server to check you have credit before sending whilst contract will send then add the charge to your bill)
Jun 15, 2017 | Cell Phones
Will not let me send or recieve pictures but i have picture messaging on my plan. keeps telling me bad gateway?
it's an IP/Port setting in your internet settings in the phone. Generally that's sent to the phone in your activation. Your carrier should be able to resend that without much trouble, or in some handsets you can enter/change it manually, but you'll need that information from your carrier as to what value to set that to.
(try powering the phone off for a minute than back on and try it... just to check your connection...)
Good luck!!
8^)
Jan 04, 2011 | Cell Phones
Picture no sound
Reset the tv back to factory setting,by unplug,repluging it an hour later.Go in ur tv AUDIO setting reset it,now it back to factory setting,Should work,not than the tv Tuner board recieve the broscast signal boad is have problem must br replaced.
Jun 02, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
I forget my password how can i reset it plz send the solution now..
hi im rain im going to give you the code to soft rest your nokia.
-----------------------------------SOFT RESET-----------------------
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
if that does not open your phone you can also try a hard reset.
A hard reset will erase all the user data and restore the phone back to factory settings.
It will erase everything passwords pictures music . But you'll be in and able to set a password of your own. THe hard reset code is.
------------------------------------------Hard Reset-----------------------------------
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone IF it can't be replaced.
Nov 17, 2009 | Nokia 1100
Trouble with MMS, texting and internet work fine, but cannot use mms.
get the mms service activated and get the settings for mms from ur service provider
Jul 21, 2009 | LG Incite Cell Phone
Flashed from verizon to metro pcs cannot get pictures or applications or on web how do I configure phone to connect to metros web settings?
first, go to this website - http://bushe102.googlepages.com/Moto_flash.htm and download this file - MetroPCS - MPC_V3M_01.1A.00R MONSTER then go to this link and follow the tutorial EXACTLY! - http://www.hacktherazr.com/guides/verizon-razr-v3m-v3c/flashing/flashing-your-phone-general - and it will basically unlock all of the factory features of your V3m, it will use Motorolla's original gui and will be much faster and work better, plus you'll be able to use the internet and send & recieve pictures... make sure you backup all your contacts, photos, videos, anything you don't want to lose, and remove your micro SD memory card if you have one... if you don't do these things then reflashing will erase all of your data... ENJOY!!!
May 07, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Lg me770 shine. how do i set up to have mms
i used this for mine. it works alright for recieving and sending. but im still having trouble recieving from black berries.
go to menu
settings
connectivity
network
network profile
bearer: GPRS
APN: wap.cingular
user ID: blank
password: blank
primary server: 0. 0. 0. 0
secondary server: 0. 0. 0. 0
then press ok.
now go to menu
messaging.
message settings
multimedia message
network profile
profile name: Cingular MMS
MMSC: http://mmsc.cingular.com
internet mode: http
proxy ip: 066.209.011.032
proxy port: 80
connection: media net
hopefully this works for you guys.
Dec 11, 2008 | LG Shine KE970 Cellular Phone
Duo phone
do you have internet on you phone because it will not work unless you have the internet connected... i got the internet shut off on my phone and now i cant send or receive pics anymore either.
Jul 27, 2008 | Pantech Duo Smartphone
Nokia N70 trouble with galary after saving pictures
you do one thing , you select image from your PC ..right click on it & go to its properties,uncheck read only & hidden option & then trfr this image to your h.set .most probably you will be able to trfr that pic to other phone.If you are successfull in doing so ,then you need to trfr all images again in the same manner .
sometimes if you have hidden any image in PC or have clicked read only.then after trfrng that image in your h.set you are not able send them to other phones.
Oct 18, 2007 | Nokia N70 Cellular Phone
Blu Studio 5.0 S D570I Unlocked Dual Sim Phone with Quad-Core 1.2GHz Processor, Android 4.1 JB, 5.0-inch IPS High Resolution Display, and 8MP Camera Black Logo
Top Blu Cell Phones Experts
Lawrence Oravetz
Dakshinamurthy...
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
