Question about GE Washing Machines
GE Washer stuck in wash cycle and not draining.
Hi, i have GE washer model GFWN1000L1WW, that keeps getting stuck in the wash cycle around the 20 something minute. It front loaded drum doesn't move and you can hear the machine humming and clicking once in a while. The door unlocks and the start button just starts blinking. Can't drain the water because can't get past this cycle. Any help would be appreciated. Thanks
  • Jerry Smith Mar 31, 2015
    Should be a small trap door at bottom front. This allows access to the drain pump cleanout. The pump could be blocked. Be advised that if you unscrew the cleanout while tub is full the water will come out onto the floor. Unplug machine before doing this.
  • Claudio Santos Mar 31, 2015
    thanks Jerry, forgot to mention thats the first thing i did and trap/filter is clean. How can i get to the pump?
  • GE Master
  • 5,323 Answers
Humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Posted on Mar 30, 2015
Testimonial: "Hi, the drum does turn and takes in the water after it measures the load, it then washes for about 15 minutes, at which point stops as if to let water drain and simply gets stuck there humming very low; then unlocks the door and start button starts blinking. From other posts I read I suspect to be the water pump, especially knowing the washer was in unheated yet piped room where temps got below freezing. Any thoughts? If I'm right, how do I access the pump? Thanks again"
  • Jorge Rendon
    Jorge Rendon Mar 31, 2015
    YES MAY BE THE PUMP AS IF U HAVE A DRAIN PROBLEM DUE TO BLOCKAGE IN HOSES OR PUMP, U MAY GET A LIGHT HUM SOUND ALSO. U CAN CHECK IT MANUALLY BY TAKING PUMP OFF AND TRYING TO TURN THE PROPELLER BY HAND AND INSPECT BY EYE SIGHT FOR ANYTHING STUCK IN IT. ALSO CHECK ALL HOSES FOR OBSTRUCTION
Krazytech
  • 725 Answers
SOURCE: front load GE wont spin or wash
I can't find your models breakdown but it sound like a bad motor. if it drains and fills you have a good pump. if you had just a bad motor control if mostly would agitate. If the motor hums then you are getting power to it.. if you have no hum you can check for power with a meter.. if no power you have a bad control.. if you have power you have a bad motor... let me know what yo find out.. krazytech
Posted on Sep 09, 2007
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
SOURCE: I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Posted on May 28, 2009
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
SOURCE: ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Posted on Sep 04, 2009
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
GE Washer keeps getting stuck in drain cycle
When you replace the timer before did you tighten up the connectors? and you can figure out your budget I can't $60.00 for a new timer or $1000.00 for a new one. if it lasted for a few years I could find a use for the money elsewhere. But if it has other probems then by all means replace the machine.
Aug 06, 2009 | GE WBSR3140DW Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
ck wiring to motor be sure all conections are tight lid switch is ok since will agitate also ck control bd for connections most likely suspect all ck ok is control bd itself
May 20, 2008 | GE WBB4500EWW Top Load Washer
Washing Machines Logo
117 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
