Question about Canon PIXMA MP210 InkJet Printer
Why can't the printer start up?
No power through cord
    Sergeant:
  • 317 Answers
Replace the cord. Also check the wall socket with a multi-meter. Try different wall socket.
Posted on Mar 30, 2015
E120n ALL LIGHTS FLASHING
switch off you printer. pull out power cord from source, wait for 5 minutes then plug in back the power cord to the source and switch back ON your printer
Sep 02, 2015 | Lexmark E120n Laser Printer
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
I have an HP Photosmart c4795 printer and it has a mind of its own. There is an error code (?) of 824C1300 on the printer screen. Help
Hello rcassity. The error code you are receiving likely is the result of a problem with the printer's power adapter. Be sure to double check that the power adapter connected to the printer is the proper one and that the Voltage of the printer matches that listed on the cord. You can also try resetting the printer's power by following a few quick steps: Start by unplugging the power cord from the printer and then from the wall so that no charge is going through it. If the power cord connects into a power module (resembles a block) separate the cord from the module. After waiting for 15-20 seconds reconnect the cord to the power module. Then plug the power cord directly into the wall outlet. Continue by connecting the power cord to the printer.
Lastly, press and release the printer's ON/POWER button to power the printer back on. Be sure not to hold the power button down.
I hope this helps! Be sure to reply if this has not completely resolved your issue.
Feb 28, 2011 | HP Office Equipment & Supplies
How to reset 3920 printer or restore it to its original settings.
Follow these steps :
1. Press the "Power" button on the printer. Allow the printer to start up. When the printer becomes quiet, it is ready. 2 Unplug the power cord from the back of the printer or unplug the power cord from the wall outlet. 3 Wait for a few seconds, and reconnect the power cord to the back of the printer or plug the cord into the wall outlet. 4 Press down on the "Power" button on the front of the printer. Allow the printer to finish the start up internally. 5 Place some paper in the feed tray. Run a test page to realign the ink cartridge.
Jan 13, 2011 | Office Equipment & Supplies
Printer won't start
1. completely unplug power cord from wall socket,
2. unplug power cord from printer
3. unplug printer cable completely from computer
4. unplug printer cable completely from printer.
5. let printer stay disconnected for approx 1 minute
Now securely:
1. reconnect the printer cable to the printer.
2. reconnect the printer cable to the computer
3. reconnect the power cord to the printer
4. reconnect the power cord to the wall socket
turn printer on
You may find that a connection has simply worked itself loose over time.
Mar 29, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Error and power light blinking.
Here is the Waste Tank Full reset.
Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Mar 30, 2009 | Canon BJC-85 InkJet Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Plz help me
do an nvm reset. When the printer is on, pull out the power cord. Hold OK and cancel and reinsert the power cord. When the scree goes blank, release the buttons and unplug the power cord. After 10 seconds, reinsert the power cord and start up. That might clear the problem
May 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printer takes a long time to start
Hi! Sorry to hear of this issue! There are a few steps you can do to diagnose the issue. If these steps do not work, let me know and I can suggest other steps or which part you may need to order. I can be emailed directly at: bosscomputers@comcast.net or http://bosscomputers.org Follow the steps below to ensure power is properly supplied to the printer: Check the power module part number against the part number listed in the User?s Guide to ensure the proper power adapter is being used. Disconnect the power cord from the wall outlet. Disconnect the printer data cable from the printer. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning. If the power cord does not work on the other printer, it is defective. Replace the power cord. If the power cord works on the other printer, then this printer is defective. Service your printer. If another printer is not available to test with, carefully inspect the power cord for damage. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer. Again, if these steps do not work for you and the issue is still present, then the printer will need a specific part - and I can tell you how to order, install, etc, so that you can do the repairs yourself! =) Just email me at bosscomputers@comcast.net Please rate my help for you too, so that I can track your progress as well as helps me get a better rating =) I really appreciate that, as well as hopefully being able to get your issue resolved/fixed!! ~Darrin~
Jun 10, 2007 | HP DeskJet 890c InkJet Printer
Canon PIXMA MP210 InkJet Printer Logo
old marine
old marine
