Question about Cell Phones
How to move device storage to sd on poloroid ptab782
We have a lenovo tab2 A8, with a 64 GB microSD card installed. With both netflix & amazon prime video, in options, there is no selection to download to the SD card instead of the internal storage.
First, go to Settings > Storage and check if the "Default write disk" is set to "SD card". Then go to Settings > Apps and swipe to the left until you get to "SD card". Below will be all the Apps that can be be moved to the external SD card. Click in the box on the right and another page will come up. About in the middle of the page will be "MOVE TO SD CARD" tab. Tap on it and wait until it finishes. Then go back and pick another App to move. You should be able to download apps directly to the external SD card. I haven't done that on this device and not all apps will download to the external SD card (the app maker can restrict downloads to only the internal memory. This tablet is one of the rare few Android devices that allow moving Apps to external memory.
May 25, 2017 | Amazon Tablets & eReaders
I have the fierce 2 and I have a sd card in it for memory but for some reason it keeps saying low memory space???? I have uninstalled a lot of my apps and disabled the ones I never use. Nothing works
So some devices have a primary storage that the device tries to use. Try finding a setting that changes data saved to an "external storage device" or try moving some files over to your SD card manually and just download things straight into your phone.
May 07, 2017 | Cell Phones
Use of storage card
Gordon, Move the stuff on tablet to the SD card to free up space.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Move Android Apps to an SD Card
Galaxy Tab How do move photos videos and other files on my Samsung Galaxy...
internal storage full how to move to SD card
Aug 04, 2016 | Tablets & eReaders
I get this message when trying to connect to wi fi. But I have an sd card and storage is fine?
You have an SD card, and there's plenty of space there, but . . .
The main storage in your device is full. Move some files/pictures, etc to your SD card, and the problem will go away.
The SD card and the internal storage are separate, and your device can't move stuff automatically.
Feb 23, 2016 | Tablets & eReaders
How do I install apps on the SD Card?
You need to go to application manager and chose any app you want, once you click on them you will get the option to "move to SD card" this option will enable you to move your apps to SD card and save device storage. This feature is not available on older android devices tho and software versions
Feb 09, 2016 | Cell Phones
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Jan 04, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
How do you move internal storage to the sd card to free up internal space
touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do I transfer game apps to the sd card
You really need to study your manual of the device (I don't know what it is, because im not that good in guessing) how to transfer them. Some devices allow you to install apps on an SD card, some only allow the SD card as a kind of external drive. A place to store apps, but you can't run them from the card. You need to free some memory in the device and then install the app.
Apr 26, 2015 | Cell Phones
How do I change the download settings from phone storage to sd card and transfer my music to my sd card on an android Alcatel one touch pop icon
Phone setting (the gear)
storage device settings
change primary storage from device to SD card
most files can be move by clicking option in top corner
really hope this helps?
Mar 01, 2015 | Alcatel Cell Phones
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
