Question about Garden
My engine cuts off when we engage the blades - Garden
  • 1,169 Answers
Make sure the operator's seat switch is fully connected. The newer versions now contain a shorting strip which when disconnected or loose will cause the engine to die.
Posted on Mar 30, 2015
    Sergeant:
  • 317 Answers
First check under deck and clean any grass or debris from around blades, belt, bearings, pulleys, etc. Might also need a tune up.
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
  • 79 Answers
SOURCE: 18 hp craftsman 2 44 inch cut engine dies when blades engage.
HI
Check wires going to safety switch under seat.
Posted on Apr 07, 2009
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
Cutting blade won't engage
with unit off look under at deck and inspect cable and pulleys and belt adjust and or repair
Sep 28, 2016 | Garden
Engine shuts down when cutting deck engaged
This is probably due to a misadjusted or faulty safety switch on the rider's seat. There is a deadman switch there that will shut down the mower if the rider gets off the seat with the blades engaged.
Mar 06, 2015 | Garden
Why does my rover rancher stall when i go to engage the cutting deck
1>the pressure switch under the seat may be malfunctioning? (it will cause the engine to die immediately when trying to engage the cutting blades because it thinks your not sitting in the seat.
2>dirty or clogged air cleaner element will cause engine to die when engaging cutting blades. This can be tested very easily by removing the air cleaner element and then trying to engage the blades again. If this works then replace air cleaner element immediately before running the engine anymore.
I have personally experienced both of these problems myself more that once.
Feb 17, 2015 | Garden
Toro 20056 engine runs but the cutting blade does not engage
you have a Toro and for whatever reason it is listed in the flat panel TV area.
Aug 29, 2012 | Televison & Video
Operator presence switch cuts off engine even if blades not engaged
Hi, you must have the blades disengaged and the park brake locked on before you can get off it. Regards Phil.
Jun 26, 2012 | Husqvarna Garden
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engaging blades kills engine
there is a safety switch somewhere toward the bottom of the engagement handle if this switch is bad it will kill the engine there is also a switch under the seat that could be bad
Aug 23, 2009 | Garden
Engine cuts out when engaging clutch or engaging blades..
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
