Microwave Ovens Logo
A
Anonymous Posted on Mar 30, 2015
How to remove H97 on screen? - Panasonic Microwave Ovens
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
5helpful
2answers
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
16helpful
My Microsoft says H97 and won't start running and goes back to H97.
The "H97" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and Panasonic customer service to find the proper part for the microwave.
15helpful
COMO REPARO UN MICROONDA PANASONIC CON ERROR H98
H97, H98 o H99 significa que hay un problema con el inversor, magnetr?n, o el circuito de programaci?n digital.
Debido a las tensiones letales utilizados y producidos, no se recomienda que una persona sin experiencia de trabajo en estos. Yo recomendar?a que se ponga en contacto m?s cercano de servicio autorizado de Panasonic.
Soluci?n de problemas de circuito inversor (U) y Magnetron
Este horno est? programado con un sistema de auto diagn?stico c?digo de error que le ayudar? a solucionar problemas, H97, H98 y H99 son el fracaso y el inversor siempre magnetr?n ?reas problema en el circuito. Esta secci?n explica los c?digos de falla de H97, H98 y H99. H97, H98 y H99 aparece en la ventana de visualizaci?n poco tiempo despu?s de clave de arranque es presionado y no hay oscilaci?n microondas.
Forma alternativa para solucionar el horno con aire acondicionado Ampere medidor utilizado.
H97, H98 y H99 aparece en la ventana de visualizaci?n un corto tiempo cambiar clave de inicio es presionada y no oscilaci?n de microondas con amper?metro de CA utiliza para solucionar problemas.
Compruebe filamento del magnetr?n abiertos o en cortocircuito a la carcasa antes de proceder a determinar un buen magnetr?n.
Espero que esta informacion le sea de ayuda (recuerde valorar esta respuestas gratuita).
14helpful
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
17helpful
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
4helpful
H97 error code and excessive heat
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
