Question about Bissell 12-Amp ProHeat 2X Upright Deep Cleaner 92002
Does the rotating powerbrush come off so we can clean it?
There is hair wrapped around the rotating brush and we would like to see if it comes out so we can clear it all away plus we want to clean in the area around the brush
  • Bissell Master
  • 10,291 Answers
Yes they do. You have to remove 2 screws on each side where the brushes mount. You can easily remove both brushes. No need to pay attention to which brush is which. Either one will go back correctly.
Posted on Mar 30, 2015
My Rooma 500 series, when I press the start button to go....it sounds like it wants to move forward and the sings a song and doesn't move
I agree with the previous poster, every time you run Romba, you have to empty out the dirt compartment, take the beater brushes off and pull the hair, lint and thread off the brushes (if you use a cat or dog brush this works fantastically) and remove the lint that's wrapped around the ends of the beater brushes. Every other time, you need to remove the thread and hair wrapped around the rotating brush (sometimes you need to remove the Phillips head screw holding this on and really clean it out). Finally the rolling ball wheel needs to be popped out using a narrow, small screwdriver and all the stuff trapped in there removed.
Feb 23, 2015 | iRobot Roomba 560 Robotic Vacuum
Floatting brush makes it hard to go forward
Most vacuums have an adjustment at the front so when you go from linoleum floors to thick carpet you can raise or lower them. Try raising or lowering it. Also every vacuum with problems I've ever looked at has needed a serious cleaning. Hair gets caught and wrapped around the wheels, hair gets caught on the "beater" bars and slows down the whole vacuum. Finally string or thread gets caught around everything. My wife does a lot of cross stitch and knitting projects, so I have to dismantle and clean our vacs about once a month. Finally if the air filter is clogged, then air can't pass through it. Change the filter or rinse it out in the sink. You'll breath a little better after you do this too.
Aug 14, 2014 | Vacuums
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I have a bosch bagless jet 12 amps/1450 W which I got secondhand. the switch to operate the powerhead (the rug brush) no longer gives me any results. I don't have the right tools to unscrew the plates and...
quite likely it has no actual motor .many of these newer machines use an AIR MOTOR that when the suction is great enough it spins the brush quite well . dog hai and human hair wraps around the ends of the brush shaft and eventually get tight enough to stop the brush totally .
Dec 05, 2017 | Bosch Vacuums
Brushes will not rotate.Square hole that brush fits in will not turn.
Pull out the 2 pieces on each end (don't be afraid...use a plyer it will eventually come out) - clean it with WD40 (you'll probably find hair wrapped around end pins) .... Spray again w/WD40 or a lubricating grease and put the ends back in (I used a hammer, again don't be afraid - it's metal and I've done it seveal times).
Sep 10, 2008 | Hoover Vacuums
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
I am wondering how I can clean the inside of my bissell spotlifter powerbrush hand held cleaner? I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49876&thid=506980
Posted by carriespets on Apr 12, 2008
I am wondering how I can clean the inside of my Bissell Spotlifter Powerbrush hand held cleaner. I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it comes apart or not so I can clean it. Can you help?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Normally on the Bissell Spotlifter Powerbrush the item will comes apart from the sides into 2 halves and then you can either clean out or blow out the inside of the
Bissell Spotlifter Powerbrush, also you can take a wire coat hanger and straighten it out and bend a hook @ the end of the wire hanger and you can use the hook to pull out the clog or whatever is blocking the opening and you can also use a blower or an old tooth brush to clean the motor or to brush it off.
Always, check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 12, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Bissell 12-Amp ProHeat 2X Upright Deep Cleaner 92002 Logo
763 people viewed this question
Top Bissell Heating & Cooling Experts
Lawrence Oravetz
Tom Chichester
Are you a Bissell Heating and Cooling Expert? Answer questions, earn points and help others
