Question about Dynex 32 in. LCD Flat-Panel HDTV
I have to turn the volume up all the way just to hear it. Even then theres a hissing sound. How do I make it clearer.
    Sergeant:
  • 278 Answers
Turn the volume down on the remotes all the way, then adjust with your hand on the actual tv, or if you are playing a dvd, might have the audio video cables wrong
Posted on Mar 30, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dynex Master
  • 1,745 Answers
Is that problem related to ANY input (i.e. cable, DVD, VCR)?
I hear hissing noise from my laptop (acer aspire 5738) while i watching video and songs
Sir if you're using VLC player or any player that goes beyond the limitation of volume of the computers then don't use it.
Go for normal windows player or real player
Dec 13, 2012 | Acer Aspire Notebook
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
Weak sound from TV after dvd/vcr hookup
Use the volume control of your converter box to increase the sound level.
Jul 25, 2009 | Samsung DVD-V9800 DVD Player/VCR
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
Hissing sound at low volume
have you tried to replace your rca cables? sometimes these tend to wearout at the connection point from being pulled off from products they might have been plugged into.also check all your wires for any fraid areas where wire might have been crincked under such items as sofa foot pegs and such. hope this helps
Feb 28, 2009 | Audio Players & Recorders
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
No sound,volume bar works
Sorry I dont have a manual but it is available at http://www.servicemanuals.net If you put your ear close to the speaker, with the volume turned up, do you hear any hiss or buzzing? If you dont it could be a bad speaker,headphone jack(if there is one), or the audio output IC or ascoiatated componets. If there is a hiss, then theres a problem with the audio processor or switching IC. If your not a tech, you should not be experimenenting around inside this TV set!
Sep 01, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
Dynex 32 in. LCD Flat-Panel HDTV Logo
53 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
