Question about Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
/lfgf3014lbcwhat does f31 mean - Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
  • David Kassin
    David Kassin Apr 04, 2016
    Check the sensor probe connections for damage like corrosion or off color. Make sure it is plugged into the socket, all the way, when the oven is in use. If the connections are sound, and not separated from their respective contacts, replace the temp probe.
  • Official Brand Answer
  • 2,267 Answers
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Posted on Apr 02, 2015
What does F31 mean on Frigidaire stove?
Thank you for your inquiry, friend!
Based off what you have described your Frigidaire range is displaying an F31 error code and you would like to know what it means. An F31 error code means a shorted probe connection. This could be a possible problem with your sensor probe, control panel, or probe connector. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue you may need to seek help from a professional technician for proper diagnosis and repair. Best of luck! -Matt
Aug 12, 2015 | Frigidaire Kitchen Ranges
Error code F31 on hotpoint wd72
I find no F codes for it only E 30 or 31 means motor failure and call service
Mar 18, 2015 | Hotpoint Washing Machines
F31 on my Frigidaire oven how do I fix it?
Good Afternoon friend, thanks for your post!
Based off the information you have been able to provide an "F31" error code stands for a shorted probe connection. Typically this means you could have issue with the RTD (resistance temperature detector) sensor probe or the wiring harness between your control panel and probe connector. Since it could be any one of these under lying issues I would recommend a professional come out and properly repair your appliance. Hope this helps. -Matt
Sep 17, 2014 | Frigidaire Kitchen Ranges
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
What is code F31
The F31 error code signifies that the heat sink in your washer got too hot. The motor control unit (MCU) stops the motor and sends the error the the central control unit (CCU) and the CCU resets the MCU. After this happens 4 times the F31 code will show.
It could be an electrical issue in either the MCU or CCU. Many times simply unplugging the unit will fix the problem. Otherwise, service must be called for.
A&E Factory Service is a nationwide servicer. Their telephone number is 1-800-905-9505
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a professional series frigidaire stove and it keeps showing an error code of F30. What does this mean?
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jan 16, 2010 | Kitchen Ranges
I have an error code F31. What does this mean
f31- suction pressure protection. Short gas or no gas. Check for leak and rectify.
Nov 14, 2009 | Panasonic Room Air Conditioner CWXC104HU
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 | Ovens
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
151 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
