Question about Tools & Hardware - Others
Hammer will not rereat after driving staple - Tools & Hardware - Others
    Sergeant:
  • 317 Answers
Give it a few shots of oil...
Posted on Mar 30, 2015
Ryobi problems
Check to make sure you don't have a staple stuck under the hammer. If the spring feed is working, then something is keeping the staples from sliding under the hammer. Can you hear the hammer hitting? Does it leave an impression on the wood?
Jul 29, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
My bht150 bostitch is jammed
First slide off the rubber grip This will expose a pin that you will need to remove. Remove the two bolts on top of the hammer with a 10mm wrench. These bolts hold the striker plate guide. Place the hammer in a vice to lightly compress the hammer head. Remove the allen head bolt located on the end of the head. This bolt holds the striker slid that strikes the staple. Remove the pin that you see that was under the rubber grip. Just tap with a punch and then you should be able to remove it with a small set of pliers. Now slid the enter assembly back just enough so that the jammed striker slid will come in contact with the striker guide face. Turn the hammer over and strike the top of the hammer on a piece of wood. This should free the slide and jammed staple. The staple and slide will come out. Take a file and deburr the slid and add a dab of grease to it. To reassemble, Attach the slide guide first, but leave it loose. The rest is reverse order. Hope this helps.
Jan 03, 2013 | Stanley Tools Hammer Staple/Tacker -...
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
Staples will not shoot flat. Have to hammer them
well most home hardware ones all do that if used on anything hard/heavy timber.....if it is a heavy industrial one it may need anew spring.
Jul 22, 2010 | Staples Arrow T2025 Staple Gun For Flat &...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Jammed staple-need to remove top of gun to remove
pull all staples out and take a screw driver and hammer drive the plunger back down into stapler till the hung staple is released
Nov 04, 2009 | Arrow T25 Staple Gun
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Compare staple guns
A hammer tacker is a device somewhat similar to a staple gun, except that the mechanical energy from the user's muscles is stored — as in a hammer — as momentum of the gun itself, rather than as compression of an internal spring. This type of stapler is typically used for insulation, roofing and carpeting.
Aug 27, 2008 | Do it Best Imports/ Jaun Yei 326409 Cable...
PaperPro 1110 Prodigy metal stapler Has ceased up. How do you open the top to access the mechanism? thanks Gerard
My PaperPro Prodigy stopped firing staples. Examination of the hammer mechanism was fine. (apparently sometimes an internal part can break) Check with stapler opened and no staples. Hold the safety lock pin down with a fingernail or sticky tape so you can check operation of the hammer mechanism. Should withdraw to clear staple compartment and then fire. If this looks good, examine the roof of the staple compartment. Mine had a little lump of brown grunge in the roof of the staple compartment next to the hammer - stopping the staples from sliding up into firing line. Scraped it out and works fine again.
Apr 02, 2008 | Cell Phones
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
