Question about pch.com
When you are prompted to put in a password, where do you put it?
Ive put in email an password will not accept
there is an option that will "I can't access my account " on it. It will prompt to type your email address. There is a security code that will prompt you to type and then click submit. Password will be sent straight to your email.
Aug 26, 2011 | Yahoo Mail
Putting a password on my router , pls help
If you are referring to put a custom password for the router itself.
1. open up your browser
2. put in the url -> http://192.168.1.1
3. a username and password prompt appears: input just the password (which is "admin")
4. go to the administration tab
5. input your new password twice.
Aug 23, 2011 | Linksys Wireless-G WRT54G Router
Start computer up asks me for password then it shuts down what is going on? It won't stay on.
computer loads basic system files threw the bios (Basic input output system) When the user set's a bios password it will not load the windows environment or win loader files until the bios password is entered. if you see a black window asking for password your seeing a bios password prompt.
Manny people buy computers aftermarket or used and cannot get past this. best tip is open the tower and pop the bios battery out and reboot with it out. go to the bios setup window and disable security now, put the battery back in and you will not see the password prompt again. if physical access to inside of tower imposable then we stop here.
If the password is a windows login prompt you will have to login safe mode to disable the faulty driver causing the issue.
once windows loads go to start then run and type msconfig then press enter. you will see microsoft configuration window and will go to the services tab at the bottom put a check in hide all microsoft services, now uncheck all the ones left and make sure the checkmark is on before doing so. this is goingto allow windows to load normally without third party drivers and you can fix the problem by enableing them till it fails to boot again.
Aug 12, 2010 | Dell Dimension 2350 PC Desktop
Forgot my password in my g3
Root user is special user in Mac OS X, has high privileges and rights to make any type of change to the system, and is different than administrator. If you forgot root password, see how to reset Root user password using different methods in Mac OS X.
How to Reset Root User Password on Mac OS X
May 11, 2010 | Apple PowerBook G3 Mac Notebook
PS 2 - Password unknown?, reset password.
When prompted to input your password,press the SELECT button,then input '7444' You may now put in a new password.
May 06, 2010 | Sony PlayStation 2 (PS2) Console
How do I put a password on my d-link 300 Dir Router
You need to access your router's web configuration interface. To do this, you need to connect a computer directly to your router and visit http://192.168.0.1 using any web browser.
When prompted for a credentials:
user name = admin
password = <blank> leave blank
When you successfully access the interface, you can set an admin password so that not everyone can access the administration page.
Feb 12, 2010 | Office Equipment & Supplies
Cannot access v3515 as password put in by customer
can you access any login? if so you go to the command prompt type
net user (user id to be changed) *
then press enter and you will be prompted to enter a new password twice.
This is if the account you log into does not have admin prvilieges which you could then just just right click on my computer select manage> select local users and group> then users> right click on the user and reset their password there.
You can also use winternals erd to reset the password if you can get a copy of it. May GOD bless the developer of that truly an IT life saver.
Dec 10, 2008 | Fujitsu Siemens CELSIUS Mobile A Notebook
There a password on my computer that I did not put on there is there a password from the company put on there?
There is a password prompt for the HDD password.
Unfortunately I did not assign this password how can i break the password or delete it.
Nov 18, 2008 | Acer Computers & Internet
Password
Hello, if you are using a vb program, i know a code that will allow you to make a password protect your programs. But you are prompt to enter it in every time you start the program.
Private Sub Form_Load()
passwordbox = InputBox("Please Enter Key")
If passwordbox = "Put Your Password Here!" Then
MsgBox "Welcome!"
Else: MsgBox "You have entered the wrong password"
Unload Me
End If
End Sub
You can try this. Hope this can help you in some way :)
Feb 29, 2008 | Computers & Internet
Watching a movie
Hey snugglebear,lazooo, and Guest,
Try this.
7444 is correct, but you have press the select button when it prompts you for a password, and THEN put in 7444.
This will prompt you to enter a new password.
Hope it works.
-Chad
Dec 09, 2007 | Sony PlayStation 2 (PS2) Console
pch.com Logo
Top pch.com Computers & Internet Experts
James Castro
Level 1 Expert
tony wahlman
tony wahlman
Are you a pch.com Computer and Internet Expert? Answer questions, earn points and help others
