The sound is muddy and has a hissing sound when volume is up all the way, just to hear the tv.
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Mar 30, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,745 Answers
Is this problem appears on any input? If so then have your TV serviced, no obvious DIY solution.
There is a "hissing" sound on low volume. Whazzup?
Do you have a cable box connected to it? I'm sure you do .. You might have the TV or the cable box at max volume ..
If you are using the TV as the main volume control try to lower the volume from the cable box, maybe to mid volume.
If you are using the Cable box as the main volume try doing the opposite from the above..
Hope this helps.
Sep 21, 2010 | Vizio VL260M TV
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
Weak sound from TV after dvd/vcr hookup
Use the volume control of your converter box to increase the sound level.
Jul 25, 2009 | Samsung DVD-V9800 DVD Player/VCR
No Sound on Toshiba 57H81 projection TV. Picture is fine.
The sound amplifier IC has went bad and needs replaced. Call a good TV Tech.
Check with the BBB 1st before you decide on one.
Jun 19, 2009 | Toshiba 57H81 57" Rear Projection...
Hissing sound at low volume
have you tried to replace your rca cables? sometimes these tend to wearout at the connection point from being pulled off from products they might have been plugged into.also check all your wires for any fraid areas where wire might have been crincked under such items as sofa foot pegs and such. hope this helps
Feb 28, 2009 | Audio Players & Recorders
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Volume
I am no pro but I hooked speakers up by using the ourputs at the back. You have to plug into a reciever or amplifier though first. You cannot just hook external speakers up mwhich is what I believe you are doing...
Rich
Jan 19, 2009 | Toshiba 32D46 32" TV
PS32500 32" TV Problem
The sound that you hear is coming from the sound detector not working or not receiving any audio. If the set is set to a second audio (SAP) program this could be you trouble. Some programs are broadcast this way. (such as Spanish for Spanish speaking people. Check you audio program settings.
Stargazer
Feb 19, 2008 | Proscan PS32500 32" TV
No sound,volume bar works
Sorry I dont have a manual but it is available at http://www.servicemanuals.net If you put your ear close to the speaker, with the volume turned up, do you hear any hiss or buzzing? If you dont it could be a bad speaker,headphone jack(if there is one), or the audio output IC or ascoiatated componets. If there is a hiss, then theres a problem with the audio processor or switching IC. If your not a tech, you should not be experimenenting around inside this TV set!
Sep 01, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
