Question about Jenn-Air Refrigerators
Fresh food section too cold
I have figured out the damper is not working properly. The temperature in the fresh food compartment is less than control setting yet the damper was still open and allowing cold air to enter the compartment. The only way to close the damper was to manually hold the damper door up. The knob on the side of the box does rotates on its own power when the door is held up to provide clearance. Now the question is how do I figure out which of the many possible parts (e.g, the control harness,the damper control assembly etc) is causing the problem. I really don't want to go through a process of elimination since I don't have the time or money. Your help would be much appreciated. Thanks Edit: The damper is working for opening the door when the frig temp exceed the 38 degree setting but doesn't close when the compartment set temperature is reached but continues remain open and let cold air in indefinitely.
  • Jenn-Air Master
  • 5,323 Answers
Check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM
Posted on Apr 07, 2015
catriver
  • 878 Answers
SOURCE: fresh food compartment not cold, light is lit when door closed
Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
Posted on Oct 28, 2006
  • 74 Answers
SOURCE: GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Posted on Aug 28, 2008
  • 163 Answers
SOURCE: FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Posted on Mar 11, 2009
  • 98 Answers
SOURCE: Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Posted on Sep 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Posted on Nov 13, 2009
Frigidaire plhs267za is to cold and frezzing the food. what do I check
Good Morning friend, thanks for your post!
From what you have described your Frigidaire refrigerator is too cold and freezing food. I would recommend you check the temperature to make sure it is set to a factory setting of 0 for the freezer and 37 for the fresh food side. You can also check to make sure that there is not food in the freezer blocking the damper from closing. The damper is located near the top of your refrigerator.
Place you hand in the rear of your fresh food compartment to feel if the air is too cold or the damper periodically closes. This could be the cause of your refrigerator freezing your food. If you damper is not working properly you may need to replace it. If your damper appears to be in working order your thermostat or control panel could be the issue. I would suggest having a professional out to perform a diagnosis. If you do not have a professional contact you should visit your manufacturer's website to locate a technician in your area. Good luck. -Matt
Feb 28, 2015 | Frigidaire Refrigerators
Why the freshfood compartment is to cold
There are 2 sets of controls on your refrigerator. One controls the thermostat The other controls a damper door that allows some of the cold air from the freezer to reach the fresh food area . It sounds to me like you are adjusting the thermostat when you need to be adjusting the damper door.The damper door (depending on the model) will have a mechanical linkage or a potentiometer( adjustable resistor control) and a servo motor that directly controls a door that lets more or less cold air in from the freezer compartment, you need to check the position of this control and door to see if it is working properly. If not repair the damper If it is working properly then you could have a defective thermostat.
Aug 01, 2014 | GE Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Refrigerator freezes everything
Depending on who made your Kenmore will help determine what the problem is most likely. Many times the thermostat can be the blame but with different brands some making auto dampers that have their own thermostat to regulate fresh food temperatures by controlling the amount of cold air coming from the freezer to fresh food section. Some models have an auto damper while others have an electric controlled damper that is controlled by an additional electronic sensor. The first three numbers of your model number found most times around the fresh food compartment door is where to find your model number, number should look like this example 321.2134567 Click Here=> Kenmore Who Made it for Them? Get the full number and I will be glad to help you, Thanks Sea Breeze
May 10, 2012 | Kenmore Refrigerators
The food on the refrigrator side is freezing. the water line is not working so i assume its frozen as well.
Hello Tina,
The problem with it freezing in the freshfood section is going to be because the air damper that opens and closes to let cold into the ref. section is stuck open and too much cold air is entering into the ref. compartment. This is a fairly common occurence with the GE refrigs. and by replacing the fresh food air damper which is located in the upper left corner of the fresh food compartment it will open and close properly and not allow too much cold air to enter where upon it freezes everything.
GENE
Sep 30, 2011 | GE PSW26MSR Stainless Steel Side by Side...
The freezer is running and cold, the refrigerator seems to be getting warmer like as if the cold isn't transferring. Is there a fan suppose to be running or what?
It is quite common for a refrigerator to begin the first signs of a defrost problems once he fresh Food section begins to warm. Auto Dampers are an additional component to check while searching for the true reason for Fresh Food compartment warming. First look inside the freezer compartment and and see if there is a layer of frost building on the rear wall. If yes you will need to manually defrost unless you have anothr place to store the freezer goods. Unplug refrigerator and then remove the rear panel of freezer to get a good look at the snow covering your evaporator coils. Defrost with a hair drier. Now we need to look for the cause Auto Damper, Click here for the photo location of these parts=> MSD2756GEW Controls Section the adaptive defrost control is most likely the problem and is listed in the photo as location 13 and the auto damper
61005971 Damper Control Assembly
61005988 Adaptive Defrost Assembly
The Auto Damper model refrigerator has two controls and both have capillary sensing.
The Auto Damper controls the fresh food temperature and the Freezer Temperature
Control guides the freezer temperature. The fresh food compartment temperature is maintained by a damper assembly located at the back of the temperature control housing. Changes in air temperature cause the damper door to open and close. A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the coldest position increases the flow of freezer air into the fresh food section. The freezer compartment temperature control warms at a faster rate and cools at a slower rate, increasing the compressor run time necessary to maintain a satisfied freezer temperature control.
Click Here=> Here is how to test a Maytag MSD2756GEW Auto Damper
There is always other possiilities but I see two other things that may cause this and that is the defrost heater with defrost Thermostat=> 61006199 Defrost Heater Assembly
I know this was long and possibly confusing but please ask if you should have questions or one on one assistance, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MSD2756G Side by Side Refrigerator
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
COLDEST position increases the flow of
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Feb 19, 2010 | Refrigerators
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Amana refrigerator fresh food control does not work at all
first of all, check to make sure your fan is working, also check the inside compartment for the damper should be open when your rise or lower the temperature settings on your dial. when you rise your temperature dial to 5 you should feel air flow coming out of the damper, if not check to make sure that the evaporator fan is working first, if it is than check the damper door should be open sometime this damper door gets stuck on something or they break off.
Dec 26, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
