My air conditioner on my 2015 elkridge isn't working. Also there doesn't seem to be any water going to the hot water tank. Any advice
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
The hot water sounds like it's been winterized, there should be a valve on one that new. It can be anywhere but is normally close to the back of the hot water heater. Do not run the AC element without water in the tank! If you have, it will need a new element.
More info on the A/C, is it completely dead or just not cooling? Check all your circuit breakers and you also need a good 12 volt source as the control circuit and thermostat run on 12 volts.
Posted on Apr 07, 2015
bluenadas
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
  • 3 Answers
SOURCE: i have an Everstar air conditioner model R51I9/BGCE. the air conditioner stopped and the LCD indicates "P1". please help. also the water indicator light is on, where is the water tank?
Usually means that you need to empty the water reservoir, or that the bucket is not seated properly.
Posted on May 23, 2009
  • 92 Answers
SOURCE: Display says emergency tank full, air conditioner doesn't work
there is a tab on the tank,make sure it depresses it when yur reinstall tank
Posted on Jun 25, 2009
dcramer531
  • 1654 Answers
SOURCE: Air conditioner isn't blowing cold!
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
Posted on May 29, 2011
Unit will not run after about an hour until tank is drained -if a container is placed under the unit with plug out the unit will run like. An awful lot of water seems to come out of the unit.
Thing to remember about an Air Conditioner is it is transferring heat, so if you are in a hot humid enviroment you are going to condense more water, which will fill the tank up quicker.
If the tank has a spot to connect a hose to the tank, and you have a drain nearby, might be worth hooking a hose up.
a thought anyways on a fix
But the water is normal
Aug 21, 2013 | DeLonghi CF210 Portable Air Conditioner
No water coming out air conditioner
an air conditioner is what it is called --an air conditioner --and it does that by conditioning the air or removing the humidity from the air ( water vapour in the air)
the room air is sucked in and passes over an evaporator coil that is cold and the hot moisture condenses and drains off
while the air out feels cool what is in affect happening is there is less water vapour in the air so you don't feel as hot as you perspire more freely
simply put in the ambient air has a humidity of less than 30% , there will be little water in the air to condense and so the run off will be small to nil
as long as you feel cold air out , there is no problem
Dec 28, 2017 | Heating & Cooling
Our 4 month old Frigidaire FRA256ST2 stopped working today.We had an eletricain check the plug and the unit is getting power.When you plug it in and press the reset,it beeps,LCD flashes but doesn't...
A dirty or clogged air intake filter will prevent the unit from turning ON, as a safety feature. If that isn't of doesn't solve the problem. Contact Frigidaire 1-800-944-9044. As you unit is still under 100% warranty at this point. They will repair it or replace it at their option. Don't do anything to the unit, that could possibly void the warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Frigidaire FRA256ST2 WallWindow Air...
My goldstar R2403 doesn't seem to be pushing out as cold as I feel it should we just had the unit refirbished and they claim it was running ice cold sitting on the bench in repair shop, however we have...
The link below is for the Owners/Service Manual for your model Goldstar AC unit. It should be of tremendous help in troubleshooting and solving the problem. Either by you. or your maintenance man.
http://www.appliancefactoryparts.com/content/pdfs/118630.pdf
Hope this helps you.
Jul 20, 2011 | Goldstar R2403 Air Conditioner
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
I am having problems with the connections of my hot water heater. The connection of the cold water to the water tank leaks around the connection. When I tighten it the pipe twisted and it started...
Remember, that COLD water might cause condensation as it nears the Hot Water tank--
However, you seem pretty sure it was leaking-- so-- What type of piping are we working with: Copper, Plastic, or what?
Copper is the best-- but requires soldering fittings-- are you equipped to do that?
Plastic has shrink and expand problems around a Hot Water tank, and might be why you have the leak?
Tell us more, -- how far do you want to get into this?
Mack B
Jan 19, 2011 | Heating & Cooling
Jun 25, 2009 | Soleus LX-140 Portable Air Conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Jan 23, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
