Question about Elna Sewing Machines
I can not get the bobbin thread to catch, what should i do, elna primula 410
  • Lorraine McLeod
    Lorraine McLeod Mar 31, 2015
    machine appears to be threaded correctly and bobbin is in properly but wont grab the thread and pull it up
  • Elna Master
  • 1,860 Answers
Try a new needle--one for the fabric being sewed
rethread the machine--top and bobbin
make sure the bobbin is correctly inserted and turned the right way
also could be a timing problem, the machine may need to be checked
Posted on Jun 03, 2015
RickE1
  • 202 Answers
SOURCE: elna supermatic bobbin and threading instructions
Check out these instructions and diagram. Good luck. Paste this link to your Address bar... http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
Posted on Sep 10, 2007
SOURCE: Elna threading and reverse instructions
Hi
I have a Primula 310
The reverse is located in the middle of the stitch length dial, you press in the button whilst you reverse.
When threading up any sewing machine make sure the foot is 'up' as this opens the tension disks and the thread goes between. when you lower the foot the discs close around the thread and add the tension.
Hope this helps
Posted on Nov 01, 2007
SOURCE: Sewing Machine Elna 6000 model
Cannot get top thread to catch and uplift bobbin thread, have changed bottom bobbin; think this may be shuttle problem. Need to get machine in to Polokwane in Limpopo Province to a repair center, cannot find a contact number of Elna there. Can you assist?
Posted on May 27, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
SOURCE: cannot remember how to thread bobbin elna
i solved the problem after i had a closer look at the top of machine
Posted on Feb 21, 2010
Standard tension setting
I can't see your model listed, only Elna Sewing machine, which may be one of the newer ones or could also be an older Swiss made. machine. So, can't tell if you've got a top loading bobbin where the bobbin case is integrated into the machine. Or some Elnas such as the Contessa and Primula were a front loading bobbin in a case, these are a bit different in setting the lower tension.
But generally, you shouln't need to mess with the lower tension, and top tension should be in the range of 5, sometimes 4-6 depending on what you are sewing. If you are having top thread issues its more likely to be a gunked up tension device or something missed in the threading path causing the issue. If you can add in your actual model I may be able to assist more specifically.
Aug 26, 2013 | Elna Sewing Machines
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
I need a manual for an Elna Special machine. I am not sure of how to thread the machine properly and I don't know what one of the dials on the front of the machine does.
There is also a Yahoo group for Heirloom Elna owners which this model is.
You can find threading diagrams and manuals at www.sewusa.com. the supermatic will be closest to your Special. This webpage has images of threading the bobbin; all Swiss made Elna's have this wonderful top loading bobbin system and they are great. Important: use Elna bobbins, they have holes on the TOP ONLY. When you wind the bobbin, ensure the thread winds evenly by nudging the thread with your finger tip, keep the thread under tension as it winds by placing the handle of your scissors onto the top of the thread reel. Cut the thread, then place the bobbin into the bobbin case, holes upwards. The bobbin will turn anticlockwise as you pull thread from it. Follow the directions from the threading diagram, you need to "click" the thread into the tension spring. Now thread the top thread through the marked locations in the diagram. Hold the end of the thread as it comes from the needle and manually turn the flywheel to lower the needle down and up once to catch the bottom thread and bring it up to the needle plate.
ALWAYS hold both the two threads at the back of the needle plate when you start sewing, really important. I tally_girl.jpg You will have a knob with numbers going from -4 to 4, this is your stitch length dial. The negative numbers are "Reverse" normal stitch length is 2.5. The white knob is stitch width when the needle swings from side to side. Straight stitch would be zero, and then higher numbers for zig zag etc. The little wheel gives you different needle positions. And the metal slide at top of case is the reverse lever.
Hope this helps you a little. Early Elnas are all very similar and wonderful machines to use.
Feb 24, 2011 | Elna Sewing Machines
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
the needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Jul 22, 2010 | Elna Heirloom Edition 6005
Cannot remember how to thread bobbin elna
Feb 14, 2010 | Elna Sewing Machines
Wind the Bobbin
Jul 29, 2008 | Elna Heirloom Edition 6005
Dec 21, 2007 | Sewing Machines
Hi
Hope this helps
Oct 31, 2007 | Sewing Machines
Sewing Machines Logo
98 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
