Cannot get the subwoofer working with the new receiver. What can I do to fix this problem
    Genius:
  • Audio Player... Master
  • 1,054 Answers
What brand/model receiver?
Posted on Mar 30, 2015
Acustimass 15 Subwoofer Not Working
Could be the amp is burned out? Maybe that is why they left it. Not worth the effort to move
Mar 29, 2014 | Onkyo TX-SV525 Receiver
My new denon 1612 subwoofer is not working
Take it back to the place of purchase, this is a manufacture defect.
Mar 22, 2012 | Denon AVR-1612 5.1 Channels Receiver
Yamaha Rx-V367 Subwoofer not working, I have new Polk Audio PS10 hooked up with Y-Adayer and Subwoofer Cable to Subwoofer Jack on backn of receiver. No sound in Radio mode which other 4 speakers work, in...
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
May 08, 2011 | Yamaha RXV367 Receiver
Polk Audio DSW Pro 500 remote doesn't"t work. I've tried replacing the battery and was told by another technician to take the sub-woofer out and make sure the cable is plugged up to the amp and the IR...
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Mar 06, 2011 | Polk Audio DSW PRO 500 Subwoofer Speaker
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Subwoofer plug broken?
Most likely the plug is ok but the level control for the subwoofer will need to be readjusted in the receiver, If the level cannot be raised making sure your source being used has subwoofer information, then there could be a problem in that circuit.
Jul 17, 2009 | Yamaha RX-V661 Receiver
Power surge thru pioneer powered subwoofer into the receiver
Cheaper to replace the unit labor and parts costs being what they are.
Jul 01, 2017 | Pioneer VSX-36TX
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Subwoofer interferance
Sounds like you've got a floating ground wire on your wall outlet, or you're plugging the sub into a different circuit from the receiver.
Make sure your sub and receiver are plugged in to the same circuit (ideally, the same outlet) and if you still have the problem then you need an electrician to test/fix your ground wiring.
Nov 30, 2007 | KLH ASW10-120 Subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
42 people viewed this question
 Grubhead
Grubhead
