Question about Boating
What should the compression be running on all cylinders.
    Champion:
  • 243 Answers
Hello Anonimous,
If The Compression Is Between 90-120 PSI And All Cylinders Are The Same +- a Few PSI THe Engine Should Run Fine.
Compression Should Be Checked At Wide Open Throttle!
Posted on Apr 04, 2015
    Sergeant:
  • 213 Answers
Check the compression in all cylinders with all spark plugs out the numbers should be within 8psi of each other
Posted on Mar 30, 2015
1993 nissan quest wont start after over heating
Overheating will damage the head gasket and the cylinder head.
Insufficient compression in the cylinders due to leaks and the engine will not start. To begin with run a compression check on all cylinders and then any cylinder with compression not at spec run a leak down test to see where the compression loss is going.
Jun 27, 2016 | Nissan Cars & Trucks
We have a 2003 F250 thats running on 6 of 8 cylinders. My husband changed spark plugs & did compression tests. He got 0 on cylinders 2&6. Anyone have advice on what to look for next?
0 compression doesn't make any sense. it could be valves compression Rings or head gasket. I've never heard a cylinder getting 0 compression. I would do another compression test and double check it
Mar 24, 2016 | Cars & Trucks
I have a 95 Chevy 1500 truck 4by 4 and I can't get it to start I tried everything it seems like it wants to start but nothing what could it be
well if it won't start it won't start...because your engine has lost 1 of 3 things that make it run: gas, spark, and compression. Don't tie yourself into knots over what it could be. Do the basics first. 1.Check that the engine is getting gas into the cylinders.
2.Check that the spark plugs in the cylinders are getting ignition current to make blue snapping sparks when tested.
3.If you have both spark and gas to all cylinders, you should do a compression test of the cylinders to know there is enough compression in the cylinders to make it run. Without good compression readings from all cylinders, no amount of money thrown at it will make the engine run better, you have to do mechanical repairs to the engine that restores compression first.
Most times, sudden no starts are gas or spark related. Check those first. Happy Holidays.
Dec 31, 2015 | Cars & Trucks
What is the compression for each cylinder for dihatsu charade 3 cyl 1986
most petrol engine run 145psi ( low compression engines) to around 165 psi (high compression engines) regardless of the compression read there should not be any more that 10% difference between adjacent cylinders Hugh differences in cylinders indicates valve problems
Sep 28, 2014 | Cars & Trucks
Ford escort 1996 1.8i - running on 3 cylinders, changed leads have spark
Determine what cylinder is misfiring and do a compression test on that cylinder. Compare it with a cylinder that is not misfiring. You should have no more than 20% difference between the good cylinder and the bad cylinder. If it is low on compression, suspect a burn valve or bad valve seat... and it will require cylinder head repair. If it is good on compression, then look for a faulty injector or some other reason for the misfire on the dead cylinder.
May 13, 2014 | 1998 Saturn SL
04 DODGE Ram hemi cylinder 3 misfire
Check engine compression and compare. then test running engine compression most engines have about 130-170 cranking compression and about 90-110 running compression. OR bring that cylinder to its Top Dead Center compression stroke apply air to the cylinder and check to see where the air is going open throttle plate bad intake valve, from exhaust pipe bad exhaust valve, from oil cap piston rings.
Mar 23, 2014 | 2004 Dodge Ram 1500
88 softail custom starts up on one cylinder and only runs on two after about 5 miles. Changed plugs , leads & coil. Can you help
Sorry but I don't know anything about the electronics on the newer Twin Cam engines. I work on the carburetor equipped Evos and earlier model bikes. The first thing I'd do is to check the compression when the engine is cold. Check both cylinders and get the reading off the running cylinder to compare the not-running cylinder. If the compression is lower by about 15-20 psi, you may have a blown head gasket. This is one of the three things that you must have in order for any internal combustion engine to run. If the compression is alright, you need to check for fuel to the cylinder and ignition spark to the cylinder. The other two components necessary to run.
Good Luck
Steve
Mar 10, 2011 | Harley Davidson FXST - FXSTI Softail...
2000 NEON NOT FIRING ON THE #1 CILENDER
#1 cylinder not firing, check spark plug, spark plug wire, remove spark plug and use a compression tester, and check the compression of that cylinder. should have at least 65 pounds of compression per cylinder. If the compression is low, you may try shooting a little oil in to that cylinder, replace spark plug, and try running motor again. if the compression is low on said cylinder, could be due to bad piston rings. requiring a motor rebuild.
Nov 08, 2010 | 2000 Dodge Neon
Car running on 3 cylinders, changed spark plugs but still running rough
Do a compression check. You want to check and see if you have good compression across all cylinders or if you've blown you head gasket or rings. If you don't have any check engine light indicating a faulty crank position sensor, or a misfire on a cylinder, you may have fire on the cylinder but if there is no compression or low compression the vehicle will run roughly. If you need directions for doing the compression check or manually checking the Crank position sensor and other sensors that could cause this condition I recommend the Haynes Repair manual on your vehicle. Most major Auto Parts stores carry both Haynes and Chilton's manuals on vehicle. I prefer Haynes but Chilton's will do as well.
Aug 02, 2010 | 2000 Ford Focus
Running on 5 cylinders and needs new coil
If the cylinder is not working because of spark a coil may solve the problem. If the cylinder is not working because of compression, it may be a bad valve intake or exhaust bad piston rings etc. A guide to go by is when you check the compression with a compression guage. The difference shouldn't be more than 10 psi between each. Good Luck
Dec 09, 2008 | 1998 Honda Accord
Boating Logo
113 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
