Question about Casio Music
My Casio ctk 811ex wont power up anyone more.Is there an internal battery that needs replacing ? What could be causing the problem ? 2 weeks ago it was working fine
    Novelist:
    Champion:
  • 225 Answers
ALWAYS start with the "easy" things 1st. Is the AC outlet on the wall working properly? Is the "wall-wart" power supply working correctly? If no defect is found, check the DC power jack located on the rear of the keyboard. Does it seem to be loose or does moving the power supply jack up/down cause any change? New wall-wart power supplies can be purchased from Radio Shack and usually at a lower price than the original factory replacements.
Posted on Apr 01, 2015
Testimonial: "The power supply is not the problem . Its something internal ."
My Casio Ctk-3200 keyboard can't get switched on with the power line, but it works with batteries.
You probably have shorted out the power supply. Test it with an ohm meter for proper operation. If it's not working, replace it. If it is working, then the power supply board in the instrument is shorted and you'll need to take it in for repair.
Mar 09, 2016 | Casio Ctk-3200 61-key Portable Keyboard...
Facktory reset my casio ctk-491 keyboard, no sound from speakers
No sounds from speakers.
It may cause by power amp (or pre-amp) inside the CTK is defects.
Or maybe the setting for LOCAL in global mode is set to OFF.
Set it to ON.
Mar 02, 2015 | Casio Music
What do I need to do with my Casio CTK 700 which will make it run on batteries?
If you turn it over, you will see the battery compartment. It runs on 6 AA batteries. Here's a link to the manual. Instructions are on page 13.
http://support.casio.com/pdf/008/ctk_496_700_e.pdf
Feb 25, 2015 | Casio Music
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Ctk 5000 driver
I prefer, only in CASIO authorized service
Jun 29, 2013 | Casio Ctk-5000 Electronic Keyboard Piano...
Casioik90tv wont work trough power
Likely a problem with the power connector or the power adapter. Make sure you are using the original power adapter as often replacements don't work and universal adapters seldom work.
Nov 05, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Casio CTK-651 keyboard wont switch on
An internal fuse is UNLIKELY.
More likely is either a bad connection/connector at power input or a bad or intermittent power switch.
Jun 24, 2010 | Casio Music
No display light on my casio ctk 496 every thing else works
Sorry, but many of the low end keyboards do NOT have backlights. This is especially true of those that have the capability of running off batteries like the CTK-496.
The display in this is a reflectance type that needs ambient lighting to view.
Mar 13, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
My ctk 2000 casio keeps shutting off
Replace the batteries and get an AC adapter for it! These do NOT work when voltage os too low.
Nov 21, 2009 | Music
I plug in my casio ctk-800 and it does not turn on when i press the on button
If you lucky, the power jack may be at fault since it switches from external to internal battery, but most likely the internal supply is what's damaged... IC regulator possibly. A quick voltage check with a volt meter at the power leads on the main board will verify battery or xfmr supply voltage, if voltage is present then look in close proximity for an IC regulator and check for an output.
Jul 21, 2008 | Casio Lighted Keyboard LK90STADMC
Music Logo
136 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
